How does float mode work with bucket?
7,205
You push the hyd. lever just a bit past where you feel resistance when lowering the bucket. The bucket then has no hyd. pressure pushing in down (or up). This allows the bucket (with the bottom flat on the ground) to float. Which allows you to follow the contour with the weight of the steel pushing or dragging material.
Roknstevo
31
North Carolina
Thanks….I was having trouble with the bucket digging into the ground.
My Barn
Kubota, Ford
Sep 14, 2022
135
37
It's a learning curve...That you will get better at with time.
2,913
With a toothbar on - I use float a lot to level out gravel in my driveway - the backside edge (under the bucket) is about 1/2" thick and grabs just enough to pull gravel without digging or allowing rears to spin.
Float is an awesome tool for getting just a bit of material to move.
Flintknapper
L2350DT
May 3, 2022
2,006
2,546
Deep East Texas
Agreed.
Especially useful when I just want to 'smooth' a small section of driveway/other.
I just tilt the bucket over a bit, put the FEL in 'float' mode and back drag. It doesn't pull a lot material that way and will follow any contours of the surface.
Mowbizz
Bx25d
Aug 19, 2021
569
330
I have found using the the bucket float is an excercize in futility trying to get a level cut. More control feathering the bucket than in float. Backdragging is a different story. When using an implement like the rachet rake, float works fin for pulling debris/weeds
old and tired
1,919
1,297
I find it handy to fill the bucket and then use float to back drag (dirt, rocks or gravel in the bucket) adds extra weight to improve back dragging ability!
Mowbizz
Bx25d
Aug 19, 2021
569
330
Remember to use float when going in reverse only. Go slow. If you are digging in you might get a nasty expensive surprise.
Yes…I have seen instances of bent hydraulic cylinders/shafts (or whatever the “shiny” parts are called)😊
Grandad4
Apr 5, 2016
405
154
Greensboro, NC
Yes! Float is very useful, but only going backwards! It only takes a slight snag going forwards to pop the front wheels off the ground. Also nice and slow does best.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
867
795
E.
I agree.... in my soil conditions only time it works well for me is when moving snow on frozen ground. Otherwise cutting edge digs in and lifts front wheels if being to aggressive. Roll buck lip up so it doesn't dig in and bucket just floats over the ground doing not much.
