LP SB1064 won't mate with my HF quick hitch - solutions?
Showmedata
LX3310
May 18, 2022
202
169
Boulder CO
I just picked up a used Landrpide SB1064 snowblower and the blasted thing won't mate to my Harbor Freight quick hitch. The SB mounts are just a hair too wide (inside to inside). The QH works fine with my chipper and receiver hitch adapter, but both of those use cantilevered pins whereas the SB has two U-shaped pin brackets.
I'm thinking the best route is to see if I can bend the tabs on the snowblower, but they're 1/4" steel so it wouldn't be easy; I need to pull the inner tabs closer together just 1/4".
Has anybody else dealt with this issue and have a better solution?
5,152
I have heard from some local people that they have experienced the same problems with Horror Freight quick hitches. I would think long and hard about trying to modify a LandPride product to fit a Chinese-made product.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,566
2,025
Western MT
I would cut the existing tabs and weld new plate to the existing tabs. Then drill a new hole and add a new and longer pin.
Of course, the other option is to sell the Harbor Freight hitch. However, from all I've read, there was some variation of QH over the years, so the issue could be with the Land Pride attachment. That being said, my Land Pride attachments all work fine with my Land Pride QH, but my attachments and QH are only 1 1/2 years old.
Mark_BX25D
Bx25D
Jul 19, 2020
1,781
1,301
"LP SB1064 won't mate with my HF quick hitch - solutions?"
Don't buy HF for important equipment. It's never worth it.
MOOTS
MX6000
Jun 27, 2019
2,166
2,690
Canton, Georgia
Maybe something helpful here.
3,879
2,523
Modify the quick hitch. All QH's are not equal.
I had to cut my speeco QH and weld it 1/2" wider to fit most of my implements. I also had to cut a slot for clearance for my PTO shaft.
