Caught Fire!
lynnmor
B2601-1
May 3, 2021
1,332
1,045
Red Lion
Do a Google search for soy wires mice and click on images, you will see plenty of wire damage.
Dieseldonato
Mar 15, 2022
728
437
Pa
Every year we chase chewed up wires in the rides that squirrels and mice eat up. Zero soy based coverings and most are shielded. They chew the cover, shielding and the wires. They are rodents they chew stuff. It's just nature.
leveraddict
Apr 1, 2019
906
583
NEPA
Ive seen birds build a nest on the leaf spring of a truck that got used daily! Amazing the amount of damage they can cause building nests in the wrong place. I guess you had no insurance? Lucky it didnt burn to the ground!
lmichael
Kubota G2160
Apr 23, 2021
530
210
Rockford IL area
We have a robin here being very pesky. Insists the top of my garage door motor is his to nest on. I chase it out, tear it down and even if I am in there working that damn bird tries again and again.
Joisey
Kubota L47 TLB
May 31, 2015
191
125
Wild, Wonderful West Virginia
Ok I obtained my new $250 plus 41mpp1-3 sensor from MESSICK online. Did a quick part search to find out if I had the part number (melted) it would have cost me $45. So do your homework!
Now I need a 3 pin plug that will fit. That way I don't get ripped off again for $1200.
Cant find part number for it. Not in book. Any help would be apprecitated.
I have no proof, but I strongly suspect that the $45 part may have the correct part number and look like the $250 unit, but that is where the equality ends.
I've been down that road with sensors on cars. Out of twelve or more times I bought the 'identical' item for 25% of the OE unit price, I wasn't burned on the deal only once. You get what you pay for, if you are lucky.
tractorX
KUBOTA L2501 DT 5' BOX BLADE 42" FORKS PIRANHA TB 5' BUSH HOG 6' GRADER
Sep 27, 2013
81
79
Rock Spring GA.
my barn cats do a great job at S&D (seek & destroy)!
most county shelters have programs for rescuing feral/barn cats and rehoming. they also offer spay and neuter services cheap.
dont need to worry bout hawks, dogs, coyotes, coons, etc.. feral cats can fend for themselves. wouldn't give you 2 cents for a domestic cat... but a barn cat will earn his keep!
Botamon
Mar 26, 2018
238
416
Winnemucca, Nevada
Here the main problem is starlings. I've had them build nests in the battery box of my old John Deere, just a small opening where the battery cable comes through. And twice I've had to remove starling nests from the engine compartment of my Dodge/Cummins. One was easy - on top of the fuse box. The other one was in between the radiator and intercooler and it was a son of a gun to clean out.
3,058
When that EGG is Comin’ Out….. ya gotta HURRY… ‘cause that EGG IS COMIN’ OUT! 🤣
(A rubber snake on top of that motor might get the msg across!”
58Ford
BX23s, LA340, BT603, RCR1248, PFL1242, STB1072
Jan 1, 2022
248
202
SW Washington
That connector looks like a deutch style connector and is fairly common for autos. You can reorder connectors on line. The issue is the specific tool for crimping the pins to the wires and then installing inside the connector is stupid expensive. There are cheap copies/sets available but buy a couple if you do this. The cheap pin tool will typically only do a couple before you need to buy more to continue.
3,058
4,250
Was walking my dogs one evening and came around the corner down near my tool shed....to see my Scag Zero Turn mower completely engulfed in fire! Had already gotten to the fuel tanks (with 10 gallons of gas), no way to put it out.
It is thought that mice chewed a wire and caused a dead short.
Before:
After:
Homeowners insurance personal property "replacement value coverage"......I hope?
Pau7220
Aug 1, 2017
785
276
Scranton, PA
Excellent photo catalog here…
here too…
4,250
Yes, covered under unscheduled personal property.
And they were actually fair about it.
That is nice to hear!
I had a similar very fair result (with USAA) many years ago, on a much larger loss.
