barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
The headlights on my B5100 were broken/not working when I got the tractor a few years back. I finally replaced them with 3.5" LED work lights from Amazon, mounted on a piece of 1/4" aluminum 1.5" x 11.75", which I fastened to the hood just about the radiator (see second photo).. These lights are really bright and pull the same current ( 18W) than the stock incandescent glow beams, but put out betwen 5 and 10 times as much light. They're enclosed in a solid waterproof (IP69) aluminum casing w/ stainless heardware, and the pair costs less than replacing one of the OEM originals. They're not road legal, but I don't run the tractor at night on the road.
There's just enough space around the lights (3/16" or so) to be able to adjust the aim, but w/ floods it's not really necessary. Now I need to design a grill guard to protect the lights and that doesn't get in the way of the hoses and when I open the hood. I had to straighten the sheet metal a bit as the headlight area had clearly taken a hit.
I still need to add some hazard flashers, a tail light and some reflectors to operate on the road legally in WA; a rear work light on the rops wouldn't hurt either.
- Bart
The center 3 bolts hold the aluminum plate against the the top orange flange of the hood; the outside
bolts are the mounting studs of the lights. Clearances are a bit tight in the this tractor. All self-locking hardware.
- Bart
