Tools and Products - Making Jobs Easier
Nicksacco
Sep 15, 2021
757
493
Bahama, NC
Hi All-
I thought I would post some tools I use in my travels with motorcycle restoration and my tractor.
I believe tools are an investment and having the right tool for the job saves time and frustration!
Have you ever made your own tool? I have and although they were not pretty with shiny chrome, they worked!!
I invite you all to add to this thread with your ideas and such. Here are a few kickstarters:
1) Flex drive sockets - great for working in extremely small spaces. The socket itself is the universal drive.
2) Flex funnel - bend it anyway you like to get fluid from getting everywhere. Wipe it off when through. Almost as good as cardboard and duct tape!
3) Flex head wrenches - excellent for small spaces.
4) Inductance heater - Heats up bolts to red hot and makes removal easy and without burning everything within a mile when a torch can't be used.
If you have metal in your hand as I do, keep it away from the business end of the tool!!
5) Circlip Pliers - I've found Knipex to be the best.
6) Phantom Tire Sealer - This product did a wonderful job of bead sealing for me. Purportedly able to seal holes up to 1/2 inch immediately.
7) Teardrop ratchet with 120 teeth. Again, wonderful for small spaces where you need more than a 1 click swing.
8) Slim LED COB rechargeable light. Very bright, strong magnet, replaceable battery, lasts a long time.
9) Penetrating Oil. We all have our favorites - this one's mine.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,442
1,736
Kalamazoo, MI
As a machinist, I am grateful that Kubota provides prints in whe WSM for the special tools needed for some of the repairs to our tractors.
D
Deleted member 47704
Guest
Knipex are the best.
PB blaster is good stuff.
Chanceywd
Mar 26, 2021
752
705
central ny
That inductance heater is on my list of tools to get. I live in the north east and salt use can make what should be a hour job into day long struggle with exhaust bolts, well anything under the car or truck. My son uses one at work and said it works well.
Blaster cans are everywhere so I don't have to look to find. Always stock up on it when on sale at TSC.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
I would skip the tire slime. If you need a tire repair or replacement down the road you may find some shops won’t touch them, others may charge more to deal with the mess.
To add to the list though, a torque multiplier comes in handy for large/high torque fasteners (ex: bush hog blade bolts)
Nicksacco
Sep 15, 2021
757
493
Bahama, NC
Good point about the tire goosh.
I went back and forth on this but decided to go with it anyway.
I've used similar in motorcycle tires and always warn the tire place so they are not surprised.
5,161
I have found that Deep Creep by SeaFoam is the best penetrant for New England rust. It has worked where others have failed. My last resort is the torch to get it red hot, and then throw a wrench onto the nut, and try to turn it off.
4,567
Long time ago in here someone said heating things up and then melting wax onthe hot part would work too I dunno never tries it my self
Captain13
Feb 27, 2019
520
170
Kathleen, GA
Great advice. I started using Deep Creep about two years ago and it’s my go-to now.
Mark_BX25D
Bx25D
Jul 19, 2020
1,964
1,473
Yes, it it. Kroil is quite a bit better, but expensive and hard to find. PB Blaster is everywhere.
I buy it by the gallon with the spray bottle. I find it MUCH easier to control how much I'm applying than with the aerosol. Just gentle pressure on the squeeze trigger and I can apply just the right amount. Or I can crank down and blast the stuff. It's cheaper that way, too. Lowe's carries the gallons. Might be on Amazon, too.
I have tried Seafoam's Deep Creep and I think it's a tad better than PB Blaster, but it's not sold in gallons.
Pawnee
L2501
Jul 1, 2021
371
336
Ontario Canada
When doing small repairs or adjustments at home, try using the toolkit you carry on your bike. It's a good way to find out if your kit is missing anything that can easily be added.
i7win7
Feb 21, 2020
3,377
3,991
Central, IL
If you have "fat fingers" some long reach tools can come in handy
Nicksacco
Sep 15, 2021
757
493
Bahama, NC
On the PB Blaster comments (blasting everywhere) - so right!
Apparently PB has gotten the message because if you look at the newest can style (see my pic) they've added an adjustable spray control to the can that really works.
I've not tried Kroil or Deep Creep - on my list to try now.
I like to watch the Youtuber "Diesel Creek" and Kroil is used on everything there - He is sponsored however.
mcfarmall
Sep 11, 2013
1,442
1,736
Kalamazoo, MI
I've been a Kroil fan boy for 30 years and they don't sponsor me. I just know that it works really well.
Benhameen
2012 Kubota L3800 HST W/FEL and 1963 JD 2010 row crop utility
Jan 27, 2013
713
135
Southern IL.
Great thread….
I had never heard of the Inductance heater until now. Thanks!
i7win7
Feb 21, 2020
3,377
3,991
Central, IL
What is tool on left for? What is its function and name?
holds a nut or bolt for hard to reach areas, then switch to wrench to tighten it.
don't know if snapon, mac or napa had it around 45yrs ago
EDIT
just visited titereach website and found this tool
may have to order some of their other tools
Nicksacco
Sep 15, 2021
757
493
Bahama, NC
I checked out the tite-reach.com website as recommended and that is so cool. I've only needed that tool about 1000 times. Thanks for this!
I've also purchased some Fluid Film to try. My tractor has places that I'm unable to clean and paint such as inside of the structural tubing or areas just buried and too difficult to reach.
Has anyone used this? What are your thoughts?
