New LX2610SU with dealer installed Cruise Control
Dusty23
Kubota LX2610SUHST
May 7, 2021
Georgia
I'm new to the forum and to Kubota. I purchased a LX2610SU from my local dealer. I saw it had an option to add cruise control and opted for it to save my leg on long days of bush hogging my field vs standing on HST pedal. When my tractor was finally delivered they told me they had to remove the Parking brake lever to install the cruise control lever. I thought that was very odd since there is obviously an empty place right next to it for the cruise control that is standard on the non "SU" model. Does this sound correct? So I have no parking break on a brand new tractor and I see this as a major safety concern as I have already had issue with it rolling. For the time being I just bury the bucket when I park it.
Njtool
Lx2610 HSDC. BH77 backhoe
Jan 1, 2021
216
282
New jersey
Take a pic!! I have a cab and the parking brake lever is above the pedals. So the SU’s have the lever on the right side of the seat?
Dusty23
Kubota LX2610SUHST
May 7, 2021
Georgia
It is to the left below the steering Wheel. You can see the slot next to it for the non SU model cruise control.
6,526
That makes no sense. Both of mine are located right there on the left side like in your pic above. B2650 here.
Dusty23
Kubota LX2610SUHST
May 7, 2021
Georgia
That is exactly what I expected, but not what I got. The lever for cruise control works, but it illuminates the parking break light on the screen. I feel like someone missed something when installing it.
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
123
Glendale, Rhode Island
Hello Dusty,
The question is, "Does that sound correct?" The answer is "No!". I had to re-read your post to see if I had misread it. I would go back to the dealer and ask them what they were thinking of when they did it. Removing an important safety feature for any reason does not make sense. As an example, how are you supposed to safely use a PTO driven wood chipper without a parking brake? The instructions in your operator's manual probably refer to the parking brake that you don't have. For what it is worth, I have attached the parts breakout for the parking brake you should have.
Let us know how you make out with this issue. I am curious to hear what kind of "yeah, yeah, that's my story and I am sticking to it" answer you get.
Good luck with this issue.
Dusty23
Kubota LX2610SUHST
May 7, 2021
Georgia
Hello Dusty,
The question is, "Does that sound correct?" The answer is "No!". I had to re-read your post to see if I had misread it. I would go back to the deal and ask them what they were thinking of when they did it. Removing an important safety feature for any reason does not make sense. As an example, how are you supposed to safely use a PTO driven wood chipper without a parking brake? The instructions in your operator's manual probably refer to the parking brake that you don't have. For what it is worth, I have attached the parts breakout for the parking brake you should have.
Good luck with this issue. View attachment 59474
Thank you for this breakout. Do you happen to have the one for the standard LX2610 model? It should show the CC lever as well.
Njtool
Jan 1, 2021
216
282
New jersey
I have a cab model. The parking break looks like it might have a cutout for something else. But my cruise control is on the control panel to the right of the seat
Njtool
Jan 1, 2021
216
282
New jersey
My 4wd is below the seat.
I never would have guessed the controls were so different between the SU and standard models.
19thSF
Mar 1, 2020
408
123
Here is the speed set diagram. It sure looks a lot like the brake set diagram. Maybe print both and put them side by side .
19thSF
Mar 1, 2020
408
123
Here is a pic of my B2650 ROPS (just about the exact same tractor)
FarmerJohn
LX2610SUHSD
Jan 25, 2021
25
NC
I have an LX2610SU with cruise and it’s set up just like 19thSF’s pic shows. Parking brake on left and cruise on right.
They seriously just left your parking brake off?!
edit to add pics:
Dusty23
Kubota LX2610SUHST
May 7, 2021
Georgia
Yes
edit to add pics:
View attachment 59485 View attachment 59486
[/QUOTEthey seriously left it off.
edit to add pics:
Yes sir they did. I just have the lever on the left and it operates the cruise control.
5,658
That’s insane. I grew up operating (and still sometimes operate) tractors from the early 50’s when safety wasn’t an afterthought, it was a never thought. Even those have parking brakes. I know you can ground implements to sort of hold it, but you can’t operate a tractor without a parking brake.
What would you do if you have a rotary cutter on the back and the loader off? I do that quite often. You can’t very well ground a rotary cutter with a wheel on the back of it.Guess I’d have to get a sand anchor and chain it to the axle.
That’s nuts. If the shop manager sees that and isn’t absolutely mortified, I would not feel safe letting that shop ever touch anything of mine ever again.
FarmerJohn
LX2610SUHSD
Jan 25, 2021
25
NC
If the shop isn’t willing to fix the problem at no cost to you (including transporting the tractor), I’d escalate it to Kubota USA. Or call and talk to another dealer in the area.
I can already smell the money from the lawsuits that would occur if this was a thing.
BAP
Dec 31, 2012
3,100
1,235
Any dealer that removed the parking brake on a new tractor, or actually any tractor at all, and sent it out to a customer, should have their dealership pulled by Kubota. That’s just a huge safety issue that could cause serious injuries and damage.
Njtool
Jan 1, 2021
216
282
New jersey
Out of curiosity, the LX2610 Cab has the cruise control to the right of the seat. and the 4wd lever is below the seat.
And it appears the SU and the standard models have the cruise control above the brake pedals? And the 4wd control to the right of the seat?
is that correct? Are the controls that much different between them??
FarmerJohn
LX2610SUHSD
Jan 25, 2021
25
NC
Yes.
