New guy with a BX23S looking for opinions.
5,154
Scratching my head about the 3rd function location... When you get a grapple you are going to have like 10 feet of hose. I would move the 3rd function back to the front right foot position. The rear double valve kit for the BX is a steal, have them install that kit when they move the valve. Its like $350. You will get all kinds of use out of it.
Do you know what the part number is for the rear double valve kit for the BX ($350). Asked my dealer, and was told that none was offered. Won't be the first time that the customers know more about what is available than the salesman.
5,782
your dealer is wrong, I asked mine a month ago.....
Actually I asked him what the 'empty slot' by the high-low speed lever was for he said dual rear remotes.
I've actually got the install manual for it ,'somewhere' on this PC....will look later.
now is later...
BX2419
Crash277
BX23S
Jan 17, 2021
844
621
now is later...
BX2419
i dont see on that list the BX23S. Thy said the kit isn’t available for it because of the backhoe. I did think about having them order the kit for a non backhoe BX model and trying to fit it, but there must be a reason kubota doesn’t have it listed. I didn’t want to be out the cash for something that wont work.
Ping
BX2370-1
Dec 25, 2018
335
300
Troy, Ohio
I'm not familiar with the backhoe subframe/mount on your 23S but, if I were to guess, it would interfere with the valve. Attached is a pic of the valve on my BX2370-1.
Hope this helps.
Regards,
Crash277
BX23S
Jan 17, 2021
844
621
Hope this helps.
Regards,
thanks! If I get a chance to go out to the garage today I will take a picture similar to yours so we can compare them.
Crash277
BX23S
Jan 17, 2021
844
621
I will need to take the wheel off to get a better picture. This is a 2020 model
Ping
BX2370-1
Dec 25, 2018
335
300
Troy, Ohio
likely the hoe brackets highlighted will be your issue with the valve and linkage clearance. Nothing you couldn't overcome with a few custom bent hard lines. Though, the linkage could get interesting. When i bought my kit, it was cheaper to get the whole kit than just the valve, go figure!
Regards
