Kubota Illustrated Parts Diagram
Dwats
26
15
Indianapolis, IN
Yes, I know and have looked at the ones from Messick's, etc. The problem is I'm looking from labels and their list is for a generic L3200 and not the HST, I guess. The reason being some of the labels. So I go to Kubota's site, from Google and from every link I can find on this site. Taken to a page where I have to accept T&C, check the box, hit enter and am taken to a page where it says "access only for US market" followed by an IP address. Does anybody know what gives? Thanks
And yes, I am located in the US.
5,688
Sounds like the Kubota.usa website is broken..
I just tried , from Canada,and got the same response.
Maybe try kubota.ca ( the canadian website) ? I KNOW it's up and running,been there several times int eh past few days
6,879
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
What labels specifically are you looking for?
Dwats
26
15
Indianapolis, IN
The one that concerns engaging the pto. It sits near the lever that engages the pto on the right side fender. I see no reference to a label at that spot on Messick's breakdown. I did find it on Kubota's site through the link that was posted here.
5,465
2,161
i have not had to order or replace that specific label on that tractor
on some equipment you have to buy an entire decal kit in order to get the one little sticker you want--a lot of that happens on mowers, maybe on tractors too--but again i did not have to deal with it on tractors mostly mowers.
5,688
R... your link does the same BS....
sees my IP (NOT in USA) then kicks me out. Really stupid as I could be an Americam ,up here north of the 49th, NEEDING to order parts PDQ for my tractor. Only sneaky way around is to use a VPN WITH a USA IP address. Consider I NEED a part and dealer here doesn't have it..I SHOULD be able to lookup a Buffalo area dealer,see HIS stock, cross boarder and BUY the part, to fix my tractor !
BTW simply put 'cache' is a section of PC memory that has a 'snapshot' of what you did recently. The OS will look there first to 'reload' the webpage data before going to the real website as it's a lot faster but not 100% reliable so you NEED to 'clear the cache' often (part of 'housekeeping' that few do...)
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
This one?
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
123
Glendale, Rhode Island
The site is back up this AM. This is the second time in about three weeks that the site has crashed. Odd for a big company like Kubota.
5,688
odd but understandable...
consider
1) 'they' are probably using the 'internal' system ( ie NOT the online - web based )..
2) us 'normal folk' say ..oops, system down, I'll try later or go elsewhere
19thSF
Mar 1, 2020
408
123
consider
Last time, even dealers couldn't use the app. Must have been a pain for them!
19thSF
Mar 1, 2020
408
123
hmm.. an 'app' generally means a 'smart device' not the Internet based programs...
You are correct sir! I guess that's just me using computer jargon a little incorrectly. My first computer was a TRS-80, then a PC-1, so to me instruction sets that allows a computer (or smartphone/pocket sized computer) to do useful work is an "application". I'll have to remember that "app" is understood to mean a mobile app.
Dwats
26
15
Indianapolis, IN
I've tried to access it at least half a dozen times over the past couple of weeks with the same results. I don't know if they maintain it in house or contract it out but you have to envy people who don't have to actually do their job
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
I made the mistake of searching for L3200hst. That returned nothing, so I just used L3200. The correct input was L3200H. That took me to the breakdown you referenced.
I didn’t realize the difference between the hst and gear drive units. My L3200 is gear and PTO lever is on the floor
