B7100 FEL Needed
3,069
This has come up many times - not impossible to find but damn near impossible
Some have suggested either FIND another machine with it on - and buy that, selling the first one.
Others have said to fab one up ........ unless you have metal/welding skills, that will be almost as hard.
Now I will have to say - finding it can be a waiting game - on the other hand I found after looking for 2 years the Tractor side MMM PTO that goes on a B7100 - I had one side and not the other, new was about $400.... I found one in my town about two weeks ago, I could NOT believe it!
jenkinsr
B219 will also fit. I found a B219 for my B7100 but it came off of a B7100 stick shift, mine is HST model. The framework is different under the tractor, HST is 6in longer than the stick shift. I am good at fabricating steel so I cut the frame and made fit the HST model. They are out there you just have to find it!
Babybull
Kubota B6100 w/ LA211 FEL, Scraper box
Nov 9, 2020
Sacramento
Looking for a FEL for my B7100 Not sure what fits but think is a LA211?
I just finished up adding a LA211 to my B6100. It was not made for this tractor but is a great loader with modern controls. It was a tight fit but is a good size for the tractor. I had to make all the quick connect brackets/frame support and deverter block.I have all the templates for the frame plates and mounting plates if you end up buying it reach out and I will hook you up.
DB6825A2-B9EE-45C2-812B-49176A80BE76.jpeg DB6825A2-B9EE-45C2-812B-49176A80BE76.jpeg 67EB90E4-90F1-4159-8EE4-0E8EDB984F6A.jpeg 0878AF4B-47A8-403F-A49A-50DDF32998A3.jpeg 3E26EE6D-6400-449A-A9B2-065A1A3D7147.jpeg 0D6429DD-9BC4-4DCC-B535-0FCC831EF40C.jpeg ABC84701-1665-4269-941F-5E6C34728496.jpeg 7FAA31B3-7620-47E4-85A7-8232E1F5671E.jpeg 67F27FB8-5A4D-417F-84D6-5CD0642BE263.jpeg 03C990FF-F886-4373-8667-51C8CC87386B.jpeg
kingram
Kubota B7100
Nov 13, 2020
Oklahoma
Th
View attachment 50852 View attachment 50852 View attachment 50853 View attachment 50854 View attachment 50855 View attachment 50856 View attachment 50857 View attachment 50858 View attachment 50859 View attachment 50860
Thanks for all the detail but probably beyond my welding skills.
11,125
I just finished up adding a LA211 to my B6100. It was not made for this tractor but is a great loader with modern controls. It was a tight fit but is a good size for the tractor. I had to make all the quick connect brackets/frame support and diverter block.I have all the templates for the frame plates and mounting plates if you end up buying it reach out and I will hook you up.
I applaud your adapting it, but a real strong word of warning!
You're very likely going to break the tractor in half without a subframe with rear axle bars!
Seen it multiple times!
kingram
Kubota B7100
Nov 13, 2020
Oklahoma
Anyone know is DU-AL loader company still in business? I cannot find a website Found a DU-AL loader on a Kubota B8200 and trying to find out if it will fit a B7100?
kubotasam
Apr 26, 2010
1,212
137
Alfred Maine
The Woods equipment company sold DU-AL loaders. Not sure if they still do.
N3BP
Sep 20, 2016
510
239
Lebanon, PA
I have a Du-Al Loader on my L2900. It's a 90's vintage. They've stopped making them for a while now. But I believe you can still buy parts for them.
kingram
Kubota B7100
Nov 13, 2020
Oklahoma
After many hours on the internet and if not wanting to wait looks like 3rd party co's can provide a loader for me. Woods, Koyker and Westondorf all cost about $5000. Any recommendations on vendor preferance?
3,069
Not to beat the dead horse - have you found any B7100's with loaders for sale? I bet those are in that same price range! All those brands have the subframe and valve body in a kit format?
kingram
Kubota B7100
Nov 13, 2020
Oklahoma
I have been looking and you are right, there are some out there around $5000 for tractor with FEL but are not close so is just weighing the cost against the time and effort.
gas man
b7100hst
May 25, 2019
cny
i absolutely love my koyker 110 on my b7100. they don't make the 110 anymore but i believe the 120 is the same loader. lifting power is amazing, you'll want some rear weights. the joy stick is in the perfect spot, atleast for me
3,069
as we say in the trade .......... that thar is cock diesel!!! One mean machine!!!
Babybull
Nov 9, 2020
Sacramento
Thank you for the heads up! I read that a couple of times and am working on a 3"x3"x1/4" tube that runs from the two 1" holes in the 3/8 plate that mounts to the clutch housing, under the transmission and bolts to the bottom of the rear end. Then up the back around the PTO. I will send some pictures. You can tell me what you think.
What/where exactly breaks? Transmission? clutch housing? Rearend?
11,125
Clutch housing is Number 1, it's the weak point.
