B2650 Jib Crane
YatesWeldingandFab
B2650 Rotary Cutter Box Blade BH77 landscape rake Lots diy implements
May 31, 2020
Athens, Ga
So I can’t post pics of the jib crane I fabricated until I have 5 other posts of nonsense before I post something relevant?
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
Something like that but feel free to post something in someone else's thread. Maybe a couple jokes in The Daily Chuckle, or an answer to someone else's question. :)
Bmyers
May 27, 2019
3,638
4,939
Southern Illinois
Only two more to go.
techcrewkevin
Kubota - my fathers, not mine. Always looking for ways to help improve it.
Feb 16, 2017
17
Ottawa, Ontario, Canada
Just be glad its no 25 like another forum I participate in...
You only need 2 more posts to post photos.
Sent from my new phone. Autocorrect may have changed stuff.
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
my jib crane is a 3ph boom pole mounted to a ssqa plate that i use on the loader. come on Yates dont let the spam rule keep u away.
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
I have a B2650 with loaded tires and ballast box. Jib crane may be OK to quickly move implements around, don't think tractor is heavy enough to set stuff on a trailer.
I did something similar with a Ford 4000 and loaded tires to lift 32' "room in a rafter" style rafters on 7 1/2' walls (around 250-300# each). The mechanical advantage of the lever requires more counter weight than one realizes. I'll post my pics while we wait for Mr. Yates.
Pre-test with engine block for test weight
Added extruded aluminum to boom for even more lift height (forgot to take photos)
Glassman13
51
10
Amherst Ohio
My brother-in-law helped me rig a mast to the FEL on my 2301 to lift beams for my carport. They were about 250 to 350 lbs each, 24 ft. long, 2 of them, the 2301 handled them easily. Also used it to set the 2x3 steel trusses.
B737
LX3310
Jun 9, 2019
2,022
2,205
wow thats pretty wild, did you get any pictures?!
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
Room in a truss rafters gave me a 16' wide 6 1/2' high 2nd story. Large hole in center mean lifting from the top. Finished result.
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
No, I'd set 2 or 3 rafters before going to 2nd shift job. 1x6 lumber on roof, set hammer down - it's gone but, drop a nail it'll stop 1/2 way down. Had pro's install steel.
FTG-05
Jul 21, 2013
346
190
TN
I'd like to see pics if the OP is still around.
