D-Rings vs Hooks
edritchey
2021 Ferris IS800Z - 2025 New Holland WM75
Jul 19, 2014
1,137
852
Wellsville, PA
Anyone else like D-Rings I just welded a pair onto my bucket and added a tooth bar I picked up cheap it's only 66" and my bucket is 72 so I had to make a couple pipe spacers but It'll work just fine.
I like the D-Rings better than hooks because it easy to tie rope to or use ratchet straps with and real nice if you want to shackle some nice wide nylon slings onto it.
9,776
They work great for hanging people that mention the S word too! :p :eek: :D
I like the D rings better too! ;)
greeno
B2710 w/LA402 FEL, BL4690 hoe, RB1560, GS1560, Haban 5' sickle bar, 5' JD RC
Jul 14, 2018
187
Big Lake MN
What’s the s-word (I assume it’s tractor related)?
Good idea I’m going to add that to my tool bucket.
9,776
What***8217;s the s-word (I assume it***8217;s tractor related)?
Its cold and falls from the sky!
And some of us...like in North Idaho... get far too much of it, for far too much of the year!
DANG IT... Now you got me talking about it... It could happen any moment now! :eek:
edritchey
Jul 19, 2014
1,137
852
Wellsville, PA
Maybe that's why it's taking that package so long to get there...;)
It cold and falls from the sky!
greeno
Jul 14, 2018
187
Big Lake MN
Hah! Makes sense now...too much relaxing for me tonight!
OrangeColoredTractor
2017 L2501 4WD HST
May 10, 2017
57
Washington
Any reason why you cant have both? I welded 3 3/8" chain hooks on my bucket, I placed the 2 outboard ones right over the ram area thinking to avoid flex in bucket and one in the middle. Where you have the D rings located would not impeded the weld on hooks in any way. I say do both. I have a bunch of those D rings already, I bought to weld onto my car hauler trailer to lash down the tractor.
Mainah
L2501HST, BLMX3164 blower, BB1266 box blade, BX42S chipper, Titan forks
Feb 26, 2018
100
Standish, Maine
My dealer put one grab hook at the top center of my bucket and I added D rings in line with both cylinders. Much handier than hooks imho.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,926
2,371
Near Lancaster, PA, USA
I use heavy angle with slots. They can take different sizes of chain up to 3/8". The chain can be hooked to go to the front or the rear. Strength isn't an issue (that 6' LandPride finish mower in the one picture is proof). A loop of chain enables me to use rope or slings.
I can detach from a load by lowering / dumping the bucket and backing away. this has been handy when moving multiple pieces. Hook up, move, set, disconnect and then position the tractor to snatch the next piece before getting off the tractor.
Kennyd4110
Vendor Member
Sep 7, 2013
1,426
756
Westminster, MD
www.boltonhooks.com
4,572
OK OK OK enough of the "S" ,,,, we know its coming just like Jon Sn-w said almost said it ;)
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
We sell something similar, plus a few more options as well gear towards tractors.
I remember seeing the 'bolt-on hooks' page before. Nice looking products, priced right too. My thing is, all of my shackles are 3/4" with 7/8" pin, so i needed something to fit what i already have/use. My bucket has a wider flat top, so i'm able to accommodate the slightly larger mounts with 4 bolt pattern.
SRG
Jul 15, 2017
490
N. IL
That's pretty slick.
David Page
Jun 25, 2013
393
84
Dexter, ME
Saw some of the "S" about everyday --- on the mountains when we were in Alaska the middle of July. Hope they keep it till late fall.
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
I have always liked the excavator hook from all of my years in my profession, which can be used like a D ring or open up for cable or nylon slings.
