Electric chute deflector control for B2781b blower
torch
Jun 10, 2016
2,689
901
Muskoka, Ont.
I would suspect from the description that it raises or lowers the deflector on top of a snowblower chute by means of a linear actuator.
Do you have any further info or photos?
8,537
I think he means how much does it cost. :D
200mph
Mar 3, 2017
1,228
61
PA
I’m certain you can find the cost on Messicks website.
wacnstac
loader, forks, box blade, disc
Apr 3, 2018
62
Wellston, MI
Yeah I bought a used Kubota 51" blower for my 2650 tractor. The blower has hydraulic rotate but does not have the electric chute adjustment. I want to ad one. Looks like the Kubota part runs around $580 which seems really high for what it is. Wondering if anyone has installed a generic part to substitute for the Kubota part.
RBA50
B2320, LA304 loader (B1658 QA), B2789 snowblower, RCK54-29B MMM, HF quick hitch
Apr 29, 2013
133
20
Goldendale, WA
You can pick up a linear actuator on E-Bay or Amazon for probably around $50, maybe less. I bought mine a few years ago, so I don't know current pricing.
Then you just need a switch and some wire to make it work. A heavy duty double pole double throw, monetary contact, center off is all you need. The actuator will probably come with mounting brackets, which will most likely work if you take the time to find the right placement. I think my actuator has about 8" of travel, but you don't need that much, 4" is more like it. Look for an actuator with built in adjustable limit switches.
torch
Jun 10, 2016
2,689
901
Muskoka, Ont.
I found the same: I started with an 8" actuator but swapped it out for a 4" because the first one was too slow.
