L3300 oil stick question
Podad
L3300 with LA 480 loader
May 23, 2018
10
Monroe, Ga USA
Newbie to the forum, first post !!
I recently bought a used late 90s model L3300. It doesn't seem to have an engine oil stick ???? It has a rubber plug just under the alternator but no stick.
I have looked at parts breakdown images and all them show a conventional oil stick. Am I missing something? Someone please guide me on this.
Thanks !!!
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
77
Rocky Face, Georgia
Most of them are on the left side of the block about mid way. Not sure on your model but it has one some where.
Podad
May 23, 2018
10
Monroe, Ga USA
Thanks !!!
Yes, the diagrams I found show it to be on the same side as the alternator. (left side if sitting in the seat) Maybe mine lost the stick and the hole is difficult to see????
The rubber plug just under the alternator is what I would consider the fill point.
9,776
The Oil fill plug is in the gear case, the dipstick will be behind that a couple of inches in the block.
I've seen several that hide in the wiring loom.
2,541
That rubber plug may be the left over parts of the dipstick.
My L185 has a rubber plug to seal into the dipstick tube
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
266
64
Southern IL
Not to hijack, but anyone know if a different dipstick be available for an L3301? The little rubber grip on mine is for the birds . Like to have a loop to pull.
7,207
Buy a new dipstick from the dealer (One that fits your machine). When you get the dipstick, pull the piece out of the hole and insert the new dipstick. You may have to use a bent piece of wire to get the rubber piece out. You'll see what the rubber plug is when you get your new dipstick.
9,776
No they do not offer a different one, just bend a loop in the one you have.
Podad
May 23, 2018
10
Monroe, Ga USA
The rubber plug I mention is about 1" diameter. Directly under the alternator.
I wish I had a picture to show. The tractor is at my property about 35 miles from where I live so I cant "visit" it every weekend :D
I have seen this at the Messicks site. However I have yet to find where the oil gauge stick goes on my machine.
Could be.
I fully intend to purchase one but want to assure my tractor is not an odd ball design or something.
2,541
If it is that large I it would not be the dipstick- especially since NIW STATED it’s some fill plug.
The diameter of the dipstick is around a half inch where it plugs the tube
Sorry that I was misleading you!
I suggest when you find it that you paint the outside part a bright color like red or yellow so it is more obvious to find
cliffboyer
Nov 30, 2017
266
64
Southern IL
As Jerry Reed would have put it, "Snowman only has the dip and not the stick, son...ha-ha!"
There is barely enough to grip, and certainly nothing to bend!. What was Kubota thinking?
For ease of use, this is not. I'd wager one from an L3200 would fit a 3301
[/URL][/IMG]
[/URL][/IMG]
9,776
If there is no stick to your dipstick, there's an issue, pull it out and see if the rubber stopper slides up and down on the stick. ;)
Podad
May 23, 2018
10
Monroe, Ga USA
I was able to "visit" my tractors yesterday. I found the oil stick on the 3300. It was lower and in a dark spot with the loop lying over against the engine making it hard to see. It is identical to the one shown in the image in post # 5 above.
Thanks for everyone's help !!!
9,776
I don't think a L3200 will fit or be the right length.
But you could put a cable leash on the dip stick you have now to make it much easier to remove.;)
