It is no secret it is cold in the whole USA.
alleyyooper
3301 and FL
Sep 20, 2017
69
Michigan has been having straight temps average 28F below normal (32F) and most days a wind chill of zero or lower.
My L3301 went thru the regen cycle 10 hours ago, now 10 hours later the warning lights have poped on again for a regen.
Starting in the cold then I let it idle for about 15 minutes then throttle up.
I try to run the tractor at 18,000 rpms and not idle much at all. So I got to wondering if the cold temps had any thing to do with the tractor requireing a regen so soon after the last one?
:D Al
8,704
Yes, colder temps have an effect on regens. The cold weather makes it harder for the engine to reach optimal operating temperatures.
I'm sure you've seen big rigs outfitted for winter up there with the covers over the grill to cut down on airflow through the radiator. The reason is to cut down on the cooling effect the cold weather has so the trucks can reach and maintain operating temperatures.
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
I believe Kubota recommends winter warmup at 50 percent rated rpm. I run mine for a few minutes at idle, then bump it up to around 1200-1500 rpms for warmup.
BAP
Dec 31, 2012
3,036
1,155
:D Al
Must be one fast tractor at 18,000 rpms
alleyyooper
3301 and FL
Sep 20, 2017
69
:eek: Yes it is one fast narrow track tractor and why I only run it at 18,000 rpms lol :eek:.
scary thing with the bucket higher than 3 or 4 feet and moving.
Card board cut outs over the grill? Or in front of thre radiator?
:D Al
4,383
Yep its colder than a well diggers arse,,I went out for wood -1f with the wind like - 17
alleyyooper
3301 and FL
Sep 20, 2017
69
-8 below here with -21 below wind chill and a NW wind at only 3 MPH this morning per my weather station.
I still have wood inside for my furnace. Heat wave for Sunday forecast so I will resupply then.
:D Al
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
Sorry to whine but this unusually cold stuff makes chores tough. Big horse didn't drink enough water (despite heated buckets) and I coincidentally had added a flake more of 1st cutting hay to his diet, and too cold to wet his hay outside, so he got colicky. There is a reason they call wild temperature fluctuations colic weather. So now I have to haul totes to the basement on a toboggan and wet the hay and soak it next to the furnace before hauling it back. Manure and bedding freezes in the carts and has to be chipped out to put in tractor bucket. No doubt if this was the norm we'd all have a different routine, but too late now.:(:(
Stmar
B2650HSDC
May 23, 2017
938
54
Buffalo, Wyoming
I call the really cold periods "Breaking Weather", everything I touch breaks. You have to retrain yourself to not use force, especially on plastic items. Do things break down during cold weather more or is it just that it is more of a hassle? Gas dryer quit heating, checked the vent and broke it, plastic, when I pulled it to check for obstructions. Turned out to be the igniter, $10 part but now have to replace vent cap so another $10. And on it goes.
alleyyooper
3301 and FL
Sep 20, 2017
69
It is called global warming because the poles are warmer than normal.
Can't say I am a fan of -8 below with a -21below wind chill but I will take it before that stinking 90F with 94% humidity Michigan seems to get in the summer.
Spend days indoors then in a thong sitting in front of a box fan.
On like clearing snow away once in a while, you have to mow lawn in that stinking heat and humidity every week. Can't unbundle for that either.
:D Al
8,704
:D Al
Thanks, now I need some brain bleach to get rid of that mental image :eek::rolleyes::p
Try mowing when it's 120 plus out with 90 percent humidity. :eek: Hence my investment in a zero turn :)
Back to the original topic. If you can find some card board that will slide down inside where your screen sits, you can cut a piece and slide it in place.
Gonna be trial and error to to figure out how much of the radiator needs to be blocked though.
BAP
Dec 31, 2012
3,036
1,155
2nd that. I was trying to figure out how to unread it.
2,884
"In a thong sitting in front of a box fan."
Dayum........
that hurt my feelings too!!!:D:)
A vision that cannot get out of my head quick enough!:)
alleyyooper
3301 and FL
Sep 20, 2017
69
So my tractor did start today. But it acted like. gasser running out of gas and quit. Let it set for about 20 minutes and it started again got it back down the 400' to with in 30 yards of the garage and it quit again and wouldn't start.
got my snow blower out and finished the drive and around the mail box.
Yes I had a pint of service fuel conditioner in 3/4 of a tank of fuel.
Fuel filter heater any one?
:D Al
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
:D Al
A PINT? What kind? What do the directions say? How old is the fuel in it? The kinds I have used a pint lasts several tanks. Your dpf filter might not like it, alternatively maybe you have algae from the summer clogging the filter, not gelled diesel.
alleyyooper
3301 and FL
Sep 20, 2017
69
Yup should do the trick, but what is ruber? Is it some thing like rubber?
I was looking at this one.
Our 3" filter heater offers 100 watts across a 9.5" x 3" tall silicone heating pad. It also includes 4" of velcro to secure the pad to the fuel filter. Power is provided by an included 12 gauge wire that's ready to be wired to onboard power. This filter heater is ideal for older Mercedes fuel filters, VW fuel filters, and any other similar sized fuel filters!
100 Watt Heater Specifications
3" Tall x 9.5" Long (7.6 cm x 24 cm) Heating Area
Up To 300 Deg. F Surface Temperature
5" Velcro Strap (4" From End Of Heater)
Adaptable Size
Fits filters with diameter between 3" to 4" (7.6-10.1 cm)
or a circumference between 9.5" to 12.5" (24 to 31.75 cm)
24" Long 12 Gauge Insulated Power Wire
Wraps Around Shorter Fuel Filters
Draw 8.3 Amps
Works Great With A 10 Amp Fuse
Available in 12 Volt
Ships UPS Ground from South Carolina
100 Watt Fuel Filter Heaters - 12 Volt
-- We are currently out of our 100 watt 12 volt heaters --
-- More on order - Estimated arrival - Jan 25th, 2018 --
(1) 3" x 9.5" 100 Watt/12 Volt Filter Heater
Click Here to buy the 9X2.75 GREEN Biodiesel Leaf Decal
Price:$59.95
Shipping: $18.00
Shipping sure is a rip off though. Haven't these people ever heard of USPS flat rate?
I ship 14 pounds of bees wax, 22 p[ounds of Acorns and 20 pounds of hickory nuts for less than $20.00 2 to 3 day delivery too.
:D Al
8,704
The ruber is probably a translation issue. The link I posted is coming from China
