Winter Preperation
BruceGeisert
Kabota MX-5100, LA 844, Hay bail forks; Bush Hog Mover, read Grading/Snow cut.
Aug 22, 2017
Amissville, VA
First winter with this tractor. Starting to work on getting ready. Most equipment needs some work, so you are not fixing something in a snow storm.
BruceGeisert
Aug 22, 2017
Amissville, VA
- Flushing Radiator, and putting in Winter coolant.
? Changing oil/filter for the winter; ??? Recommend???
Any other winter preparations recommended?
4,057
Fire wood check
Guinness check
Knob Creek check
Jamesons check
Dramubie check
full freezer check
gas for the grill check
Gas for the gen set check
freezer full check
battery tender check
Ahhuummm did I miss anything? ;)
sheepfarmer
Nov 14, 2014
4,441
677
MidMichigan
Fire wood check
Guinness check
Knob Creek check
Jamesons check
Dramubie check
full freezer check
freezer full check
Long underwear? Mittens? Muffler?
2,831
Fire wood check
Guinness check
Knob Creek check
Jamesons check
Dramubie check
full freezer check
freezer full check
and you only mentioned Guinness just the one time!!!:D Not sure I am proud of you or disappointed!:D:)
BAP
Dec 31, 2012
2,934
1,045
Fire wood check
Guinness check
Knob Creek check
Jamesons check
Dramubie check
full freezer check
freezer full check
Diesel for the Kubota!!!!
Stmar
B2650HSDC
May 23, 2017
932
Buffalo, Wyoming
How long can you keep/store #1 in 5 gallon plastic can in cold weather? I treat my gas and use high octane and try to keep 10 gallons on hand and have never had any issues no matter how long I kept it. 1st winter with diesel.
4,057
You can keep it all winter long out of the sun cause algae will grow in the diesel even in the winter time. Treated with white can your good to go.
Thanks for reminding me diesels is down to 3.13 for over the road. I dont know what off road is, usaly like 50 cents a gal cheaper around here any way,gota stop today
armylifer
Mar 26, 2013
2,145
916
Thurston County, WA
Fire wood check
Guinness check
Knob Creek check
Jamesons check
Dramubie check
full freezer check
freezer full check
Since Jim Beam has changed the aging on Knob Creek I have learned to do without it. I have found that Evan Williams tastes better. Check the label on your Knob Creek. They have removed the ageing statement on it. It is no longer aged 9 years as it previously was. I noticed a difference in the taste recently and googled why. It turns out that Knob Creek is no longer aged like it was. They changed in October 2016. Now it is just another blended Bourbon. The rest of your checklist looks good though.
