Auger, Am I missing something?
scottz
1988 L2550DT-GST 2001 BX2200D HST 2016 L2501 HST
Nov 27, 2015
60
Colorado
I mounted an auger on my L2550 to help plant some trees. The ground is a little hard, but certainly not rock, but the thing won't dig in. As far as I know, all I have working for me is gravity; I don't think the 3-point has any down force.
Am I missing something? Is there a way to get the tractor to put down force on the auger?
Thanks
2,831
Thanks
Few if any small machines have a down pressure on the 3 point! SO gravity is your friend there. Some add weight to the arm, some use a small auger point to help pull the bit in - that being said - once it gets stuck on something it is a real PITA to get back up - there is no reverse either!
Check you auger point, what does it look like? Some have a spiral, some have a flat spade like bit - something is needed to break the ground so the auger can bite.;):)
bucktail
Jun 13, 2016
1,261
191
MN
Doesn't look like you're missing anything to me. It's a common problem with the 3 point mounted PHD in heavier soils. I've seen down force kits for them which is basically just a weight, but the tractor isn't going to put down much force on it through the 3 point. A bobcat, dingo or similar will do better in heavy soils if that's an option. They can transmit down force. Some irrigation might help a little but probably not much. Most of the soils that have these problems don't perk very well, so you'd need to keep it wet for a while for it to work.
SkylineAcres16
Kubota MX5800 HST, International B-275 Diesel
Sep 3, 2016
40
Also, check the replaceable teeth on the auger if it is a used unit. Teeth can look okay but will be a night and day difference when you put new ones on there. I use the serrated ones. I have quite a bit of experience with PHD's.
TEC
b7510, 60" MMM, FEL, KK tiller, KK cultivator, TSC plug areator, PHD, etc..
Apr 7, 2012
10
Wrightsville, Pa.
Having done several hundred holes for trees, vines, and posts with a B series tractor I find that removing any sod makes a big difference for a good bite. Then, proceed a foot at a time, raise the auger to spin clear the dirt and continue. Trying to dig the hole in one pass will often result in a stuck auger; especially in heavy clay soil.
8,185
I found the easiest thing to do, to add down pressure to a three point auger. Go to the scrap yard, find a couple pieces of pipe. One at least 3" in diameter, and one that will either sleeve inside or outside that's about 6 inches long.
Weld the 6" piece to the outside shaft of the down tube. Then when you need down force, a buddy can apply pressure with the 4ft piece of pipe :D
Steve Neul
B5200
Jun 3, 2017
130
14
Terrell, TX
I have the opposite problem. Mine goes into the ground like a wood screw and will pull down until it stops the engine. I had to make a jig in order to let it down eight to ten inches at a time and let the auger remove the dirt out of the hole before doing another eight to ten inches. The bad is it's a two man job but it works for me.
scottz
Nov 27, 2015
60
Colorado
Yes, I bought it used and really have no idea what the cutting edges should look like; I'll do a little research. Here are some photos of what I have. Now that I look at it; seems pretty dull.
8,743
1970cs
1,124
Grand Ledge
The first picture as NIW mentioned, is turned 90% CCW. Looking at it, the exterior hole is worn off by someone that has let it wear down to far. And that pilot bit is pretty worn also.
You could weld it up? You should measure the top diameter of the flighting and then the bottom to see how much taper there is. If you are in frost part of the country and using concrete you don't want taper to your holes.
Pat
Former Cyclone fence employee
scottz
Nov 27, 2015
60
Colorado
One digging tooth is on wrong, but both digging teeth are very worn, get new teeth and maybe even a new tip.
Here are a few teeth and tip options
Looking at the new teeth, they say 9". Does that mean they are for a 9" auger? My bit is a 12" so I guess I should be looking for 12" teeth? And, I'll have to do some welding to fix that hole.
Thanks
Repair
2017 L2501 - 2020 L2501
Apr 17, 2017
152
24
Lebanon, TN
Looks like the auger will need to have the mounting boss repaired so it can have the tooth mounted correctly.
scottz
Nov 27, 2015
60
Colorado
Looking at new points. Do you guys recommend spiral point or fish tail point?
scottz
Nov 27, 2015
60
Colorado
The cutting edges I find on line have 2 5/8" on center bolt holes The ones I took off are 1". Guess I could weld everything up and drill new holes. Any suggestions?
2,051
Buy a whole new auger?
