Crank adjustable leveling link
hodge
Nov 19, 2010
2,959
535
Love, VA
I ordered (from Weaver's Compact Tractor Parts) a crank-adjustable leveling link this past weekend, for my JD 790. The price seemed reasonable, worth the convenience that it would add, and the measurements were close enough that I took the risk. It arrived yesterday- kudos to Weaver's for fast, professional service- and checked out the fitment. It was just about right, with a couple of very minor adjustements. I needed to make a sleeve for the top mount-link pin fit, because the bore was bigger than the diameter of the link pin. That was easy. I also had to make an attachment pin for the bottom, where the link attaches to the lift arm- the JD pin wouldn't work (by its design). That also was easy, and once I knew it would all work, I painted it JD green. It works very smooth, and I can reach the handle from the tractor seat. I have a total of $130.00 in it, and I consider it a good buy. I'm sure that there are numerous Kubota models that it would fit on.
https://www.compactractorparts.com/tractor-parts/hitch-kits/adjustable-leveling-box-3
mendonsy
B7500HST/LA302
May 28, 2012
359
34
Mendon, NY
Hmmm ...... I wonder how difficult it would be to replace the ends on one of those to make a crank adjustable top link???
3,316
Good idea, now you've got me thinking about it.
hodge
Nov 19, 2010
2,959
535
Love, VA
Probably the most pertinent question would be if there is enough range of adjustment for a top link.
mendonsy
B7500HST/LA302
May 28, 2012
359
34
Mendon, NY
Yeah, those probably don't have a whole lot of stroke built into them.
edit: the one from Weaver's lists a stroke just under 6 inches, so it should work if the initial length was correct.
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
My previous Kubota came with a crank leveler from the factory. I really liked it. Unfortunately, the 4060 did not have one:(
hodge
Nov 19, 2010
2,959
535
Love, VA
I know, in my case, that the particular array of implements that I have calls for some wide variety in top link length- I'm not sure if 6" would be enough stroke, for what I have.
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
A Grand L didnt come with a crank leveler?.... I think your dealer is at fault.
It has a square section that I lift up, then rotate to adjust. It's clearly how it's designed to work, but sucks compared to the hand crank I got used to!
I may look into replacing it.
torch
Jun 10, 2016
2,823
1,073
Muskoka, Ont.
Has anyone ever seen a box leveller short enough to fit a B7100 (ie: 16" at the centre of adjustment)?
9,749
The other issue would be the side of the ends, most Box levelers are much bigger than what you need.
