Question about grease zerks on my Kubota B2320.
drummerbobbyearl
Chandler
In this picture indicates a red circle around the grease zerk at the HST point. In the manual it shows that the yellow circled area is also a zerk but it doesn't look like one, it just looks like a hole. Can anyone give me some insight to this and what to do? Thank you.
mpham
B 2650 cab
Nov 15, 2016
152
Massachusetts
That just looks like a different mounting area for something else. I would not worry about greasing it.
Caboose
B2650HST
Aug 16, 2016
80
Washington State
Is your B2320 a non- hydrostatic drive (i.e. geared drive)? If so, it looks like item 1 is your zerk. Item 2 represents where the zerk would be on an HST equipped model.
Dean
2,858
I think you have it covered - the diagram in manual is showing your zerk, when they bubbled it and enlarged the picture, it is exactly what you have circled in red. There is no zerk where your yellow circle is located - if there was a zerk there - there does NOT seem to be any internal threads there, then again the picture is not clear enough to see. OP - are there threads there INSIDE the hole? and is the machine geared or HST as others have mentioned?
Caboose
B2650HST
Aug 16, 2016
80
Washington State
My post didn't read very clearly. I assume your tractor has a gear shift, not just a forward and reverse pedal/trundle, correct?
Dean
200mph
Mar 3, 2017
1,228
65
PA
6,874
Not a button head grease fitting. If it was every tractor owner would need more tools for one grease application.
clay45
L2050DT, TSC 5ft Rake, Tartar 5ft rototiller, TSC Middlebuster, TSC CarryAll
Feb 6, 2015
279
SC
The manual is confusing. The zerk is obvious. The other deal makes no sense.
drummerbobbyearl
Chandler
Great replies, all of you! Thank you very much for all your feedback as the HST is not available on this gear shifted tractor and there would be a fitting if there were a zerk there. I believe you have covered all of this for me and I thank you again.
Dontwannaflip
2016 B2601, FEL, BH, MMM
Dec 11, 2016
52
Kitsap,WA
Button Head fitting was the first thing that came to mind for me. I think they can come with or without a ball check valve. Would seem odd to mix the two types on the same equipment. Pic is from McMaster.
drummerbobbyearl
Chandler
Now I'm confused all over again! Ha ha ha ha! You may have to directly go to Kubota and see what they say. Thanks for your input.
Dontwannaflip
Dec 11, 2016
52
Kitsap,WA
Sorry Drummerbobby, I guess it's better to go to the official source and be sure. :) Curious to hear what you learn.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,495
518
Just saw this. I have the B2620 and there is no fitting there.
