2011 bx25 battery replacement
CrashmanS
BX25
Aug 2, 2014
25
Buckhannon WV
Will a normal car battery be ok in this application? I work at a votech center and get a good discount on napa batteries. There top of the line battery is less than half of oem with more cold cranking amps.
Sent from my SM-N920P using Tapatalk
2,768
The size of the "battery compartment" and the CCA is what you need to consider.
NEED not get the exact same model and whatnot - just get the correct size, making sure the terminals are on the "correct" side and see if you can get a CCA as high as possible.
The terminals can be a real PITA if backwards, I have replaced several honda batteries that the owner bought the right battery - backwards terminals - the reach of the power cables would not allow it to work!;)
With your higher CCA and correct terminal placement - you'll be fine!:)
ipz2222
L235, bx2670
May 30, 2009
1,927
chickamauga ga usa
On my bx 2670, you could not get jumper cables on the posts, they were buried in the box. I pulled the batt out, turned the batt 180 degrees, changed one of the cables to a different route and reinstalled the batt. Now I can easily charge the batt or boost anything else off.
CrashmanS
BX25
Aug 2, 2014
25
Buckhannon WV
I installed a napa legend 75 month battery in a 26r size. Was exactly the same battery. Same size all around and even had the same style vent placement. Installed and now back up and running! Thanks everybody!
