The hydraulic tube to the 3 point linkage started leaking oil at the banjo fitting under the pump on my B6001 (with a D950 engine). I found a small crack. Replace the whole tube or repair?
After some time on the net I decided to silver braze it. Last time I did this was fifty years ago!
First I found silver rod and flux on Ebay. the rods were AMC Ag130 with 30% silver and melting point 750C and the flux was Easy-flo.
Had some fireproof bricks which I placed as a small open furnace to minimize heat loss. Solved some of the flux in water and covered the crack after first cleaning it. Heated it with a butane gas burner until the flux melted and then some more. Tried to heat indirectly. Then put the rod to the tube and it melted nicely. It was then easy to cover the crack. You can remove the rest of the flux by soaking in hot water for at least 30 minutes.
The whole process was easier than I remembered!
The tube tested OK afterwards.
I found a few tips on the net here and here, There are more on Youtube
