what type and wgt of oil
Dave in DE
1976 L260
Oct 19, 2015
12
Camden DE
just bought an L260 and want to change the fluids/filters as usual. am planing to us Rotella 10/30 or 10/40 hr meter shows 466 hrs on new motor. would either of those be fine? will be run mostly in summer mouths mowing ditches and field edges at my hunting property
2,794
just bought an L260 and wont to change the fluids/filters as usual. am planing to us Rotella 10/30 or 10/40 hr meter shows 466 hrs on new motor. would either of those be fine? will be run mostly in summer mouths mowing ditches and field edges at my hunting property
at your local wally world:
http://www.walmart.com/ip/ROTELLA-550019913-Diesel-Motor-Oil-Rotella-T-1-gal-15W-40/44944739
or if you want a little better protection:
http://www.walmart.com/ip/ROTELLA-550019921-Diesel-Motor-Oil-1-gal.-5W-40-Bottle/44944174
make sure you get a diesel oil.......regular or synthetic, your choice;)
SCPOret
B7510HSD, LA272 FEL, Mohawk Brave shredder, Modern rear blade
Jan 21, 2013
12
Alvin, TX - USA
Manual says (Below 32°F use SAE#10 or #10W-30) (32°F to 77°F use SAE#20) (77°F and above use SAE#30)
I use 10w-30 year round. You can also use a 15w-40 (Rotella or Delo 400.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I use 5w30 synthetic year round in all my diesels. You should be fine with the 10w30 or the 10w40 either. The 10w30 would be my personal choice of the 2.
Like 85Hokie said, be sure to use a diesel grade oil no matter what weight or brand you choose.
