Sears Mouldboard convertion HELP
9,385
I take it you B7001 does not have a three point lift on it, that would be the easy mod to get you up and running.
en_teng
B7001
Aug 13, 2013
39
Pacific Islander
IDOL north Wolfman yes i have 3pt hitch my problem now is i need to modify it to like this one i need the dimension please anybody thanks i appreciate it.,,:D
4,363
I guess Im missing something here. If you have the plow already and a 3pt hitch I cant see why it would be a problem setting it up to the 3pt, if its to wide you just measure it ,,if I am not mistaken the with of the pins should be between 24 and 28 inches if I remember right,,, the height should be about 16 I think,, again I could be way off base with these numbers and I mean WAY off base,, but still if you have the plow you should be able to fudge the ting
en_teng
B7001
Aug 13, 2013
39
Pacific Islander
pin<------------------------------>pin is 24 to 28 inch do you have single buttom plow please.. can you measure please if you have time i appreciate it :D i just want it to fabricate almost same as the original so the height from base to top of A<-- is 16" i start cutting it tommorow thats why need some infos thank you idol skeets
sorry for my ignorance:p
4,363
What does IDOL mean??
Tooljunkie
May 13, 2014
4,150
My take on this- weld on a 2x2 inch heavy wall tube. And build a three point trailer hitch. 2x2 reciever. I find it very useful for moving trailers, my driveway grader and soon a tool for making shallow trenches. All on/off like a trailer hitch bar.
en_teng
B7001
Aug 13, 2013
39
Pacific Islander
somebody say this
26 in wide and 7/8 lift pins, 3/4 top pin, 18 in height for cat I
32 in wide and 1 1/8 lift pins, 1 in top pin, 24 in height for cat II
38 in wide and 1 7/16 lift pins, 1 1/4, 27 in height for cat III. The height can vary to suit the equipment.
and somebody say this one
Category Hitch pin size Lower hitch spacing Tractor drawbar power
upper link lower links
0 17 mm (5***8260;8") 17 mm (5***8260;8") 500 mm (20") <15 kW (<20 hp)
1 19 mm (3***8260;4") 22.4 mm (7***8260;8") 718 mm (26") 15-35 kW (20-45 hp)
2 25.5 mm (1") 28.7 mm (1 1***8260;8") 870 mm (32") 30-75 kW (40-100 hp)
3 31.75 mm (1 1***8260;4") 37.4 mm (1 7***8260;16") 1010 mm (38") 60-168 kW (80-225 hp)
4 45mm (1 3***8260;4") 51 mm (2") 1220 mm (46") 135-300 kW (180-400 hp)
http://www.tractordata.com/articles/technical/threepoint.html
i have b7001 that i believe cat 1? does i am right
26" or 20" or like idol said 24 to 28.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Since your going to custom make the 3pt attach frame.... make the lengths exactly the same width as the most common other 3pt item you switch off and on. That way you will not have to adjust turnbuckles, and if you plan it out well may not have to change top link length either.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Here is a similar example of what Tool junkie is recommending except that instead; make the plow attach via receiver tube instead of permanent attach as this fellow did. Kills two birds with one stone. (fixes your issue and ads a tow ball too)
http://www.orangetractortalks.com/forums/showthread.php?t=20556
en_teng
B7001
Aug 13, 2013
39
Pacific Islander
yeah i dont have problem with the attachment. reciever tube are limited available on my area, my concern was the original width" i cant make the width same as that TSC subsoiler the intendly for the B2601 my tires are narrower from that.
9,385
Width is supposed to be 26" to 28" for cat 1
Your problem is you can't get that width because tires are too narrow, Simple fix move the hub and make the tires wider.
Or just make your implements narrow like 21" if you really need to keep the narrow tire width. ;)
en_teng
B7001
Aug 13, 2013
39
Pacific Islander
Thank you I appreciate it, going to cut it now
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
301
northern lower Michigan
Guys,
did I totally miss something here because to use it would have only
required a couple of bushings from the farm store Tractor Supply etc.
That had category zero pins on the plow and a zero to category one
bushing would have allowed the lower 3pt arms direct hookup.
Probably have to do something with the top bar hookup too of course
I've done the zero to one and one to two on my Kubota and Belarus both.
Adjust the lower arm width and the top link and get busy turning dirt.
Al
en_teng
B7001
Aug 13, 2013
39
Pacific Islander
Guys,
Al
yeah thanks sir but im aint working in garden i use the plow in a sugarcane furrows thats why i need it adjustable left and right.
thats why i need to make my tires narrow,
i tried 25" need cut the 2x2 wood (pattern) to again i just maximizing the lenght of the bar
