GF1800..anybody have one??
kuboman
721
Does anyone have one of these front mount mowers? I have a hydraulic question about them but I need someone who has one or runs one.:D
kuboman
721
Hi Kuboman,
Throw the problem out there and maybe someone can help you out.
Well I did do that earlier but got no response but here goes again. At idle with warm oil does anyone have the problem of the mower (pto) cutting out while the mower deck raises and then reengaging as the deck tops out?:confused:
Now I know there are thousands of these units out there so I should be getting many responses.:cool:
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I have been trying to find a GF model Kubota to try and see what you are talking about but I can't find one. The closest thing I can find is a G model mower. What do you have?
kuboman
721
Check Kubota.ca. They are not sold in the USA anymore but thousands were.
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
681
155
Rising Sun, MD
My neighbor has a 20 year old G1800 and it is a three cylinder diesel lawn tractor with a mid mount belly mower. I don't think they came with a "front" mower.... or at least that is what my neighbor says.:rolleyes: Butch
handyman
Kubota B7100HST-E
Sep 18, 2009
452
Dayton,Tn.
:eek:I Have a dumb question have you had someone else raise and lower the deck and you watch to see if one of the hydraulic lines may be getting pinched off as deck moves up and down? handy
KubotaTech
None- I get to play with everyone elses stuff
Apr 1, 2010
185
PA
I've seen these before, GF is a front cut. If the PTO is Hyd driven, and it cuts out while you lift the deck, it sounds like there is not enough hyd oil supply to run both the deck and the lift. I assume this is a new problem, and has not always happened since you got the unit. I would start with hyd filter(s), just to be sure there is an ample supply of oil. I have seen a similar problem on a front cut because the filer was damaged- it was dented in pretty bad and didnt have the right amount of oil being supplied.
Bulldog
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I think Kubota tech is right. I was wandering if it was a hyd driven deck but if so it sounds like the lift is taking pressure away from the drive. If the filter and oil level is good I would say it's time to tap into the hyd system and do a pressure check.
kuboman
721
It is a hydraulic clutch and everything is alright. I have tried other ones and some do the same and some don't. I was just curious as to how many are like this. It must be just a design weakness.:eek:
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
When you look at how it works it's not surprising that it disengages when lifting the implement. Guess it really doesn't matter much though, you usually aren't cutting when you are lifting the mower!
Ed
1kubotakid
Kubota tractors and engines
Nov 19, 2013
27
Webberville mich
be sure the ground wire is good
3,965
If he hasn’t figured it out after 15 years, then I think he should just take it to a shop and have it fixed.
Welcome to the Asylum…….(y)(y)
