new to me tractor
hal1937
L2600f
Oct 10, 2014
shannon, ms
Hi. I just bought a little kubota L2600f tractor with 300 hrs on it. Not sure what fluids have been changed in it so I decided just to change everything front to back. I do not have a manual. I'm wondering if someone could tell me what type of transmission/hydralic fluid should go in it. I did some reading and some said gear oil and others said hydralic fluid. And also it has a fill hole in back and fill hole in middle by gear shift with a sight glass window on side. Does both holes fill same thing or is each for different reservoir? All recommendations and input on this tractor much appreciated.
8,772
Yes both plugs will put fluid into the same place, read the sight glass to fill to level.
UDT or SUDT-2 is the 2 best choices for your tractor and for a long healthy life.
2,835
And spend the money on the S.............S udt2
S = synthetic...............mo better, cost more , but that ol girl is worth it !:D
