bleeding fuel line M4900
MikeE
M4900
Apr 10, 2010
Carrollton, Ga., USA
My manual says to bleed lines by just pumping on the primer pump on top of the fuel filter. It doesn't say to open the injector nuts and allow air to escape. I am having air collect in the fuel/water separator bowl. Tractor will run for 30 minutes or so before it dies. I can bleed the air out by following the manual but it collects again. Am I just not bleeding it properly, or is it likely it is sucking air into the system somehow? All my connections seem to be tight.
traildust
B7610HST 4WD, LA352 FEL, Gearmore 2 Spool Top & Tilt Box Scraper
Jan 27, 2010
1,490
Phelan, California
It sounds like to me that you may be getting air form a bad connection. As you know the injectors are higher than everything else you mentioned and the air bubbles are not going to go back down, they always go up.
Kubota engines will consume quite a bit of air and keep on chugging till it bleeds out. Most people are able to drop the filter and install a new one with out ever having to bleed anything.
I think you are going to have to find the leak, may be lots of fun!
Check all hoses and connections. You might even have to use a vacuum pump and do leak down checks on lines and hoses.
I don't think it will be that hard to find.
Scott
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Could be that the rubber O ring seal around the glass bowl is shot and needs to be replaced. Take it off and have a looksee if its cracked or worn out.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I'm not sure on the Kubota water separator but I ran into this on a C 15 CAT engine. The primary filter was under vaccum, not pressure while the engine is running. If the drain wasn't good and tight it would suck air in but didn't leak fuel out. I could see the bubbles as they entered the bowl. These filters had a removable bowl with a rubber gasket seal also. If the bowl had just a small amount of trash around this gasket it would leak there as well. I only mention my expreience here with a CAT because I have had trash so small that it couldn't be seen with the naked eye but it would screw up the seal and leak air. I never understand why it leaked air in but no fuel out but it was like that every time if not cleaned properly. Maybe trash could be your issue as well.
