PTO switch reversed on M5140
Tallahassee Kubota Man
M5140HD/LA1153/LandPride RCF2072/DirtDog disc/RakeMaster grapple/Caroni tiller
Took delivery last week on a new M5140. Love the tractor....perfect size and power for my needs. There is one issue though. The PTO switch engages my mower just fine, but it works in reverse of what it should. I questioned the salesman and he said he thought there were 2 wires that somehow got reversed. He's checking with his mechanics, but haven't gotten an answer yet. I don't see how the wires could be reversed, seems to me the design should prevent that from happening during assembly. To me it's more likely that the PTO switch itself needs to be taken loose from it's bracket and reversed. Ever hear of this?
Mark
2,771
Mark
I am not familiar with that Kubota, but is it a pull switch or a lever? Either way there has to be a closing contact system in place, a simple open/closed switch.....I do NOT think that the wires are backwards, because you are simply closing the loop. MAYBE the switch has been replaced with a NORMALLY CLOSED SWITCH and you need a NORMALLY OPEN SWITCH.
Some safety switches are normally open, and then you sit on the seat and the contacts close, others are closed then whatever you do it is open.....a lawnmower cutting in reverse is a type of switch like that, normal open, then you throw it in rev and it closes the contacts and the mower dies......
just a thought..........
8,495
Actually have heard of both situations happening on switch installs, and either change will fix your problem. ;)
8,495
Something does not set right, you do not have a electrically controlled PTO, you have a cable controlled PTO, so no swapping wires.
What exact model is it, there are different control setups per model.
2,771
8,495
Wolfman, looking it up .....what the hell is a Hydraulic Self-Modulating engagement ?
A mode of automatic control in which the action of the final control element is proportional to the deviation, from set point, of the controlled medium. :rolleyes:
Simply put, automatic hydraulic control. :D
2,771
Dayum, had to read it three times before I knew that I could NOT understand it.....:D:D:D - why in the hell doesnt Kubota just say......
Hydraulic controlled .......:D - and thank you!
North Idaho Wolfman, the model # is M5140 HD....hydraulic shuttle shift w/4wd. If I understand right the switch (lever) is connected to a cable which in turn physically moves the pto hydraulic control unit. So, the answer to my problem seems to be that the switch/lever needs to be taken loose from it's bracket and reversed. Will try to follow the length of the cable later to see where it goes.
Thanks all for the comments, have a great Labor Day.
2,771
Yep you got it.
Here is what your looking at:
Something still is not right......
D268xx needs to move either cw or ccw......which way is it in the picture?
Is it engaged or not? pulling on the cable takes a linear motion and converts it into rotary motion, so either the cw/ccw is backwards ....or?
looking at the picture - looking at the safety switch - is it engaged or disengaged as the pto is placed into motion?
so my question - how could it be backwards? unless the cable is routed to pull rather than push ?????
2,771
Which side of the tractor are we looking from? I'm assuming the left side is the front and the right the rear of the tractor.
ON this tractor......what hand is used to throw the lever? Left or right?
8,495
on part 030 (two slots) --where is the on position - forward or back? Towards the switch or away from the switch?
85Hokie,
If I'm thinking what your thinking, the electrical switch is not what engages the PTO, it's just a safety for the starter circuit, so swapping it around wouldn't solve the problem.
I'm thinking the valve on the side of the transmission is flipped to the top side and that's why it's working backwards. ;)
2,771
85Hokie,
now, I think that IS THE solution:D..........that would solve this riddle !!
good job - you de man with the plan ! hope that is the solution......
