PTO switch reversed on M5140
11,500
Post a picture of your setup.
The picture I posted is with the gate and lever mounted to the fender.
Forward is on, rearward is off, is yours the opposite?
Tallahassee Kubota Man
M5140HD/LA1153/LandPride RCF2072/DirtDog disc/RakeMaster grapple/Caroni tiller
Will get a photo shortly. Yes mine is opposite, forward is off, rearward is on. Just talked to dealer. Mechanic says he's seen this before and the lever assembly just needs to be turned around. Now have to figure out how difficult that is so I don't have to take it back.
9,118
When you do your post, sroll down to manage attachments. Up load your photos there. When you close out that window after uploading, it will show the photos down in the manage attachments section. Hit submit reply, and they will show up on the bottom of your post:) not sure how to insert photos into the post using the computer. Will just use the iphone and taptalk. Much easier
3,102
Took a few pictures, but having trouble posting them. When I click on "Insert Image" I get a window asking for the url of the image. ???
TKM,
hit the paperclip, manage attachments,choose file,(find the picture on your computer) click upload (you will see a number at the bottom telling you % of upload progress), scroll down and hit "close this window" then hit submit
11,500
Dang, I don't know how they did it but yep it's installed backwards!
Being that it's new tell the dealer to send someone out to fix it!
There are 2 bolts on the sides of the gate that hold it in place, remove the 2 bolts and it will flip around. ;)
3,102
They sure did screw up! Dealer's mechanic says he's seen it before, so Kubota needs to tighten up their QC process. My dealer's 60 miles away, so I'll give it a shot first.
Many thanks for these diagrams, they've been a huge help! Where do you find these?
I think the "dealer" needs to drive them thar 50 miles and be a fixing it ! ;)
Should not be your job to take it to him. :)
- kudos to wolfman once again.
