I purchased a ZP330 (propane powered zero turn) last year with around 1000 hours.
Used it all last year with no issues. Brought it out this year, it fired up immediately and I began mowing. About 20 minutes in, I got off mower to clean up some debris. I left the PTO engaged, parking brake set, and while I was off the mower, it cut off. Since then, I was not able to get it to start; it will crank strong but never start.
Got new fuel for it, and determined it was not delivering spark to the plugs (through a spark check).
I ultimately discovered the 10a Engine Stop fuse was blown. I replaced the fuse, and it will fire up and run for about 15 seconds before it blows that fuse.
For ZP330 parts and service, Kubota utilizes (refers) everything to the ZD331, since they are nearly identical.
I have researched as much as I can for the Engine Stop fuse, but cannot locate where it goes or what is tied into that system (relays/solenoids).
Can anyone provide points to check that would blow this fuse routinely? I examined the exposed wires carefully, and do not see any melted/grounded wires. I know the engine was hot at the point it cut out, but do not see where anything was damaged.
Thanks in advanced
Thanks in advanced
