I searched on this forum and found this article which was similar however different.
www.orangetractortalks.com
Back story leading up, I purchased this mower last weekend. 2013 Zd221 with 385hrs. I probably cranked the mower 30 times since purchasing it and mowed my 2 acre yard. Being so close to 400 hrs, like most in here, I decided to do a complete 400 hr maintenance to give me a fresh start. Well, I pulled it into my shop and it wouldn't turn off. So I turned the key off and within 20 seconds it turned off. (Odd). I cranked it again and then I turned it off, worked perfectly. Did that another 10 times with no issue.
Fast forward to today, I changed my air & oil/filter and went to crank the mower. Then starter engaged as normal however died within 1 second with a huge puff of black smoke. I figured it was glow plugs so I left the key on for 10 seconds and try it again. Same result. Repeat this step 10 times, then suddenly the key stopped engaging the starter. The dash lights still are on. I was hoping that the hood was open that perhaps there was a safety switch. Closed the hood. Still no starter engagement. Jumped the starter with the key on and the engine started and died within 1 second with a huge puff of black smoke. (Much like before).
Checked all the fuses except the slow blow. Any thoughts?
ZD221 won’t start. Electrical issue
Hello. My ZD221 zero turn won’t start. Battery is good. I have good voltage at the starter. I tested the solenoid and it appears good. I’ve gone through the two lever safety switches, the seat safety switch, the pto/mower engage safety switch and the brake safety switch. I get variable and...
