Work lights
Swampcollie
Mx5800, la1065 loader, rcf2772 mower, blade, disc
Aug 19, 2016
Sedalia, mot
Hi, folks
When i bought my MX5800 last summer, I had the dealer install front and rear. Work lights on the canopy. I have seen several people on this site that specified that they got LED lights.
I have no idea if I got LED's or not. I assume I can pull a bulb out and tell.
If they arn't, can I just get LED replacement bulbs to swap out?
Is there significant difference if I do?
Tooljunkie
May 13, 2014
4,150
30
Usually you can identify led lamps by the appearance of the bubl through the lens and the light it produces. Post up a picture. Or two
jcy110
BX22 with LA210 loader and BT600 hoe
Aug 22, 2015
Whitehouse Station, NJ
Here is a link to LED work lights...the type you are talking about are sealed. They do sell removable LED lights for stop, turn and parking sockets.
http://www.aliexpress.com/store/product/2-X-Cool-White-Blue-Red-1156-BA15S-13SMD-5050LED-Car-12V-Tail-Auto-External-Parking/218320_32242402252.html
http://www.ebay.com/bhp/led-work-light-12v
I have 2 of these on the ROPS, super bright. Its totally sealed and the 16 superbright LEDS do not come out.
The price has really dropped, I paid 90.00 for my first pair, bought a second pair to mount facing backward and will be installing a ON-OFF-ON switch to flip from front to rear on my BX22.
Swampcollie
Aug 19, 2016
Sedalia, mot
Thanks. Tractor is on my property 70 miles away. Will get pics later in week when im up there
Swampcollie
Aug 19, 2016
Sedalia, mot
Thanks for the leads. I was hoping to do it on the cheap and easy if i could just swap out bulbs.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
It's not that expensive to change to led lights if you look around. I bought a box of 10 18w pods from amazon for $80. They may not have some fancy name brand like cree but have worked fine. I'm sure some are better but I don't see the need. Only draw 3.2 amps so if one set isn't bright enough add another set.
Swampcollie
Aug 19, 2016
Sedalia, mot
Sorry to be old and stupid. What is a pod?! Did they fit in oem work light housing or mounted seperate?
Swampcollie
Aug 19, 2016
Sedalia, mot
I dont know what the work light circuit is wired/fused for. 96 watts would be a minimum of 8 amps plus the rear light is on the same circuit.
jcy110
Aug 22, 2015
The setup I have comes from Northern Tool, it is a wiring harness relay fuse holder and switch that you connect directly to the battery terminals. I used battery charger connectors to clamp on the terminals.
So its not connected to the light circuit on the tractor itself.
Check out northerntool.com
Butch
Sep 10, 2009
633
82
Rising Sun, MD
I changed my incandescent head light bulbs to LEDs.... man what a difference.... I got them from www.superbrightleds.com . I am in the process of putting a LED work light on the rear for plowing snow.
mrcarnage2
B3300SU
Nov 13, 2017
40
Pullman, MI, USA
I just put two LED work lights facing backward for my snowblower. I mounted them to the ROPS. They run off of the 20amp light circuit. I have 12V power going to a switch no relay needed I also replaced my incandescent headlight bulbs with LED.
