White Smoke and rough runnin
maroon man
box blade loader mower
Jun 9, 2015
9
league city tx
My BX 2660 has started blowing whitish exhaust smoke and running rough intermittently....installed new air filter, drained and replaced all old fuel and did all the trouble shooting procedures recommended. Ran fine for a while then started doing it again... any suggestions :confused:
maroon man
Jun 9, 2015
9
league city tx
No Sir, temp seems to be running a bit high but its been real hot here in Texas. reservoir says its at recommended level.
Tooljunkie
May 13, 2014
4,150
Check resevoir cold, make a mark at leve with a sharpie. Run as you normally would and recheck when cold.
Other possibilities-
Bad injector or low compression.
8,599
I would run some fuel treatment, Stanadyne, through it. ;)
1970cs
1,124
Grand Ledge
I am with NIW, with no coolant drop and white/greyish smoke and stumbling I would suspect a fuel issue.
Carry a wrench with you and when it's start to stumble, break each injector line open one at a time and see which one does not drop any RPM.
Pat
Smagner234
Kubota B5100DT FEL, B36 Tiller, 44" Mdi Mower, Front snowblower
Aug 15, 2016
42
Ct USA
I had a white smoke issue as well and it turned out to be the injectors. I had the injectors rebuilt and the injector pump and it went away, granted my engine was a bit older than yours but injectors do go bad. White smoke is unburnt fuel, you could check the temperature of the cylinders on the exhaust manifold with a pyrometer. If your temperature variation is greater than 40 degrees F then there is a fuel delivery problem or worse a compression issue. I learned this from a diesel mechanic I was talking with when I was trouble shooting my white smoke issue. Hope this helps and good luck!
Tooljunkie
May 13, 2014
4,150
After startup (cold) you can feel the exhaust manifold as it warms up, the non firing cylinder will be cooler or the running cylinder will warm up manifold faster.
