Wheel Spacers
davecal
Kubota BX2230, FEL, Snowblower, Cab
Aug 4, 2017
27
Ridgefield, CT USA
Can anyone help with some advice on spacers? I have a Curtis Cab on my tractor and it feels a bit top heavy and I was thinking about adding spacers for stability. Question is, should I, is it a good idea and is it safe? Also, what size would you recommend. Thanks for the help. Dave
8,202
Yep go right ahead, it's not going to damage anything.
Most pick the widest they can go with out pushing the tires out past what your blade or snowblower width can cover.
Also get the tires filled, that help even more with stability. ;)
davecal
Aug 4, 2017
27
Ridgefield, CT USA
Okay sounds great, my tires are filled so that's done. What about spacers on the front wheels? Leave them alone?
Also, I've seen a few spacers listed on eBay and some pictures of tractors that had them and the only concern I see is that on some of them the hub doesn't fit snuggly into the hole on the rim, there appears to be some space which I would think puts undo stress on the studs. Am I off base here? Thanks again
Lennyzx11
L3301
Dec 18, 2015
Bennington Vermont
Mine from Adaptec are snug around the center hub. Almost an interference fit. I had to file slightly to get one wheel back on as I dinged the edge installing it.
Kubota sells 2" spacers for the L series. For the rear but my manual says not to run spacers on the front.
Makes a whole different machine on a slope. With filled tires and low counterweight, mine will crab sideways before even trying to feel tippy.
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
319
169
Eastern PA, USA
Make sure that if you're going to space the wheels, you're not spacing them wider than your snowblower, or you'll be running over fresh snow. I have that issue now and trying to figure out a way around it.
Grouse Feathers
Feb 16, 2015
1,022
10
Lovells, Mi
Front spacers will not help the stability because of the front axle pivot. Spacers on the front may also cause excessive loads on the short front axles and wheel bearings
RobL
Kubota L2002DT; Kubota FEL; Wallenstein Log Splitter; King Cutter 5' Brush Hog
Jul 14, 2017
15
Edmonton, AB
I tried reversing the front wheels on my older L-series and found that the machine became a pig to steer and on uneven ground feedback through the steering wheel became extremely harsh (no power steering).
Given this, I too think that some of the steering mechanism might be over stressed and after only an hour or so of operating, I'm going to swap them back. I can't see why spacers would be any different...
8,202
NEVER space out the front wheels! It doesn't do anything for stability anyways because the front wheels pivot side to side. ;)
Tractor Dell
Kubota BX23S
Jun 13, 2017
122
Central PA
I have the 2" Bro tek rear wheel spacers on my BX23S. I can really feel the difference when I am on a hill. I don't feel as if I am going to roll over... Easy install, and I haven't had any issues with them at all.
http://www.bro-tek.com/wheel_spacers/
AndyM
BX25DTLB
Sep 21, 2016
484
149
Vancouver Island Canada
When I inquired on OTT about useful adds to my new BX wheel spacers came up very early. I do believe they have already saved my bacon when I was loading my truck on what I thought was a pretty minor slope.
All I can say is thanks (Hokie) as I am pretty sure I would have been over without them.
Brotek 2"
davecal
Aug 4, 2017
27
Ridgefield, CT USA
Just installed the spacers, love the new ride! Definitely feels more stable. Went with the 2" based on fatjay's comment about spacing the wheels wider then the snowblower. The 2" are perfect, 48" across the rear wheels with a 50"snowblower so I should be golden.
Thanks for all the advice, Dave
Rowlem
BX23S
May 30, 2017
New York
What was the part number you used for the Wheel spacers on your BX23S ?
The BX23S is not listed on the Bro-Tek site . I want to get a set of 2 inch for the back of my BX23S but not sure what ones will work .
jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Nov 5, 2015
437
Edinboro, PA, USA
I have the 2" spacers on my BX23S. Order the ones labeled for BX25D. If you have a 60" MMM you need to measure the space between your rear tires and rear antiscalp wheels to make sure they will work. If you have a 54" MMM, the 2" will not work. No MMM, no worries.
Sent from my SM-N920V using Tapatalk
Rowlem
BX23S
May 30, 2017
New York
Thanks I was hoping that they would be the same as the BX25D . And yes I do have a 60"mmm and will check the clearance before I order . Although they do say the 2" will fit with the 60"mmm.
jmf78
Nov 5, 2015
437
Edinboro, PA, USA
I'd emailed Brotek prior to ordering and they suggested measuring the space just because the welds could be somewhat out of location from MMM to MMM. Just a precaution.
Gerry Walker
B2601 Hst
Feb 6, 2023
Medford NY
Can you send a link for the Adaptec spacers? Thanks
Gerry Walker
B2601 Hst
Feb 6, 2023
Medford NY
Were can you get adaptec?
Quick
B2601, LA435, BH70, LP SGC0554 Grapple, LP RB1672 Rear Blade, King Kutter 60" BB
Sep 23, 2021
142
249
St. Clair, MO.
I used Bro-Tek 3" spacers on my B2601. Bolted right on. Very easy. Here's a pic.
