What Size Box Scraper - B2400
OhioKubota
B2400HSD, ZD28F, RTV900
Aug 9, 2010
Cleveland OH
Long time lurker, first time poster!!
New to me B2400 HSD (less than 500 hrs, 1998 Model). I'm looking to get an appropriate sized box scraper and am looking for suggestions. I'm leaning toward a 54" land pride (BB1554), but want to be sure this isn't too big.
Ed Hill
B3000 with Meteor drag snowblower and mid-mount mower; M7040 with accessories
Jun 22, 2009
51
Wheelock, VT
I have a 48" Land Pride box blade and use it on my 20 HP B1750 to good effect. My primary use is gravel driveway maintenance. One pass down on the side, return pass on the other side and a final run down the center and the drive looks great. I hope this information helps.
Randyj
B9200D / BF350 Kubota Loader / L-4530B Kubota Backhoe w - subframe / LP GS1548
Sep 17, 2009
141
Northern Indiana
Sounds like it works good.
I just bought a Land Pride Grading Scraper 1548. I'm planning on going with
the same approach. I just need to get my 3-point to work first! Bummer.:(
I've got a long gravel drive going back to my barn, and it's covered with weeds.
NC Bota
B7610, FEL, box blade
Jun 1, 2010
35
West Jefferson, NC, USA
I have a B7610 and use a 48" box blade for maintaining my gravel driveway. Works well and not sure I would want anything bigger.
Hope this helps.
Blkvoodoo
B2400, LA352, RC60, Cammond Box Blade
Mar 27, 2010
143
Zebulon NC
I have a 60" Cammond W/ 4 rip shanks, forward and back cutting edges.
That I'm cutting clay makes anything a task, I just take it slow and easy, and she gets the job done.
It is a little big but definitely workable. I do like that it wider than the track of the machine.
also makes a nice counter weight for the loader !!!
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
A good rule of thumb is have the attatchment a little bit wider then the width of the rear tires on the tractor. I have a B6100 and have a 4ft box and works flawlessly. On a rare occasion I've used my dads 6ft box but that was to move light weight bulk material such as gravel.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Eric, you have me curious. If you consider gravel light material what in the world do you move that is heavy? I have never moved iron ore but it would take a mineral like that or something in that class to be heavier than the lime stone and granite we have down here in Georgia.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Apples to Oranges, gravel spreads out in a grading box a helluva lot easier then dirt does. Well for me anyway. If I have 10 tons of gravel and 10 yards of dirt in a pile it seems like I can move gravel alot faster and efficent then I can dirt.
Bulldog
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I was a loader operator for 16 yrs and 15 of that on a yard loader at a rock quarry. It wasn't a very big quarry but between moving stock piles and sales I would load over 2 million tons per year. With a 7.5 yd loader it was normal to get 12 - 14 tons in the bucket depending on the moisture content of the rock. Loading dirt it was hard to get 10 tons in the same bucket and even then it was piled up higher than the rock would be. If you equalled the pile hight in the bucket it would be more like 9 tons of dirt. There is more difference between the 2 than you think.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
WOW thats really odd. When I was driving a dump truck 2 years ago for a local landscape product supplier, 14 tons of gravel would fill up the tandem dump truck and 14 yards of dirt filled the same dump truck up to legal weight capacity. Thats what I was judging my info on. I know when I was taking the tandem dump to the rock quarry to refill our stock pile two scoops from the quarry loader filled the dump with 14 tons of stone. So I'm guessing the buckets on those loaders would be a 7 yard bucket.
Bulldog
Mar 30, 2010
5,434
76
Rocky Face, Georgia
It very well could be the specific gravity of the rock. Some rock is lighter than others. Depending on which type of rock you are dealing with it can make a huge difference in weight. I bet the rock in your area is just a lighter product than what is down here.
Jimmysal
B1750HST, RC60 MMM, LA300 FEL, TSC 48" BoxBlade, PTO Dbar chains tongs old Stihl
Aug 26, 2010
24
Vermont
Assume density is the same or similar in both materials for the time being. The larger the gravel, the more void space will be in a pile/truck/bucket of material.
