What should I do?
Buck3343
24
US
I just brought a couple of old attachments, and I really don't know what to do!!!! I brought a Ford 782 rearblade that is 6ft. I have a kubota b7100hst. I was thinking about cutting the blade down to 5ft so I could use it. After looking these blades up they seem to worth a lot of $$$ and if so I don't want to cut it. What should I do HELP!!!!
Sent from my SAMSUNG-SM-G891A using Tapatalk
sinisterbiker
US
I currently have a 5', got a great price, 6' would of been better especially for clearing snow. I wouldn't cut it.
Sent from my SM-G930T using Tapatalk
Buck3343
24
US
Thanks,but do you think that is too much blade for my tractor?
hank2000
Kabota L3000F
Aug 27, 2016
81
louisville
Don't cut if u can't use it sell for what it is worth and get one u can use. Just my .02 worth
torch
Jun 10, 2016
2,595
839
Muskoka, Ont.
I borrowed my neighbour's 6' landscaping blade and used it behind my B7100 to level out my gravel driveway. That blade is probably twice as tall as yours. The tractor wasn't completely overwhelmed, although it would lose traction and start spinning the turf tires if I let it dig deeper than 2 or 3 inches. I think you could get away with that one for moving snow, but yeah, a 5' blade is probably a better match.
Buck3343
24
US
The blade would only be for snow removal!!!!
4,402
The answer is in the details. Put it on your tractor and use it! If you're not satisfied with how it works, then consider modifying it.
I can't imagine it being too big for a B7100. I had a 7' blade on a b6100 for a season (and the tractor was 2 wheel drive) before I did anything to it.
Ike
Kubota L 3301, Farmall Cub. JD B. Ferguson TE 20
Jul 18, 2015
324
Mich
I would not worry about the blade, but that disk could be a much bigger worry for you
Buck3343
24
US
The disk that I got with the blade was all part of the deal!!!! Kinda like getting the plow before the horse. You see I don't have a farm or anything yet, but I have dreams of getting my own land to hunt on someday soon. So that disk would be to put in small food plots and things lime that mabe just breaking the ground to plant grass seed nothing major!!!!
Ike
Jul 18, 2015
324
Mich
What is the width of your disk? If it is a 5 footer you have a lot of weight hanging over the back of you tractor so you will have super super power steering as your front wheels may not be hitting the ground. I have a 5 foot ford disk that was made for the 8 N ford tractors and it makes the front get very light when I use it on my Ferguston which is the same as an 8N. Next is according to the specs you have 16 inch wheels on the rear s I am mot sure if you can pick it high enough to get ground clearance. Next comes the biggie when you drop that into the ground expect a lot of lose of traction.
The only thing you can do is try it but be very careful when turning and make sure it is out of the ground when you turn. The price for the disk around in this area would bring maybe on a good day 250.00. The back blade which I know your tractor can handle will bring maybe 50.00 because it had been cut or wore down. What I think it was used for was a farm had it and use it to scrape off the cement barn yard. That is to bad because with that cast mold board they would bring top dollar at a sale. I think they were one of the best back blades you could get . I use to have a Ford 1300 tractor similar to the one you have and I used a 6 foot blade on it with no problem, but that had 24 inch tires on the rear. You are the best judge of what they will do behind your tractor you have them so try them
torch
Jun 10, 2016
2,595
839
Muskoka, Ont.
Suitcase weights on the front bumper will help with that.
Ike
Jul 18, 2015
324
Mich
Fill the loader bucket with sand if he has a loader. I let my neighbor borrow mine and he has a 20 hp tractor and that is what he had to do and even then his 3 point arms only raised it high enough to just clear the ground. His tractor has 24 inch tires on the rear
MikeyA
2016 B2650 FEL and 60"mmm,1998 B2400 MMM FEL(sold!) BB 4ft BRUSH HOG
Mar 6, 2010
150
West Central Illinois
I have an almost identical blade. I used it behind my 1994 B7100hst for several years. It will work great, but you will definitely need chains.
Buck3343
24
US
Thanks for all the information & advice. It's good to know that the blade will work without having to modify it. I hope to start the restoration soon, I will keep you all posted on the progress. Thanks again!!!
