What is purpose of rubber "duckbill"
lmichael
Kubota G2160
Apr 23, 2021
698
328
Rockford IL area
So on the air cleaner housing there is a rubber "duckbill" looking thing. When I bought my tractor it was ripped. I installed a new one and recently saw the new one is ripped. I hadn't even noticed it or noted any difference in the machine's performance. But, they seem to have a short lifespan so I bought 2. And will put a new one on next time I am out to use it.
But, what are they for? Does it really serve a purpose?
Bmyers
May 27, 2019
3,405
4,178
Southern Illinois
I think and I could be easily wrong, you are talking about the evacuator valve on the lid of the air cleaner.
My understanding it is faced towards the bottom when you put it on and it allows larger particles to be evacuated out of the system.
Edit: I see that Fordtech86 responded with what it is.
SDT
multiple and various
Apr 15, 2018
3,277
1,067
SE, IN
Squeeze from sides to allow debris to fall out.
6,398
It's (vacuator valve) a snug (interference fit) as it fits the airbox. On my wife's zero turn it came up missing. I couldn't find it anywhere, so I ordered a new one. Painted it orange and used a zip tie to anchor in there.
SDT
Apr 15, 2018
3,277
1,067
SE, IN
Interesting read. Though for something seemingly so important I would think it would be made longer lasting LOL.
Have one on each of my Kubotas.
Never any need to replace any, even the one bought new in 1993.
2,968
Lots of things have them.
My Yamaha Rhino has one on the air cleaner box, and another on the cooling plenum for the drive belt.
5,409
2,104
when the engine stops, it sometimes "backs up" due to compression and valve spring pressures. When it does, the intake becomes the exhaust as some air is expelled when the engine turns backwards. During that short time some dirt and such is forced back out of that valve. That is the "idea" anyway, although I've never seen it actually work. But I admit, I have not watched for it either.
On the Rhino's and other off-road equipment, it's simply a one-way valve that is supposed to catch fluids, oil and/or air filter treatment oil, and is "supposed to" let those fluids out but not allow fluids (water) to get back in. They hold engine oil and air filter oil just fine but they never seem to really let those fluids out on their own, I always manually drained em during servicing.
2001TLB
L48TLB, 60" EA SSQA Root Rake Grapple, EA SSQA Fork lift
Nov 14, 2021
62
53
Shelton, Washington
I have always thought it was for draining water that may have accumulated.
JimmyJazz
1,253
783
Pittsburgh, Pa
Neill from Messicks referenced this in one of his YouTube performances. Squeeze and jiggle out any large pieces that may have come into the intake but were not captured by the filter.
cthomas
LX2610 HSDC
Jan 1, 2017
843
557
La Farge Wi
Silverado diesels newish have them on the hood for the ram air system. Just crazy to see how many bugs come out when you squeeze it. Yes, it is disappointing to see how many people just ignore the vacuum valve when doing service on equipment.
Nicfin36
Jun 19, 2019
1,018
470
Decatur, AL
I have to replace the one on my zero turn every season. It essentially melts and turns into a bubblegum consistency. Poor material, poor placement, etc. The one on my L2501 still looks new.
lmichael
Kubota G2160
Apr 23, 2021
698
328
Rockford IL area
Mine simply "shredded". It was bad when I bought the machine (who knows for how long), so I replaced it. OEM part BTW from the dealer. Didn't pay attention to it, and just noticed it was bad last time I looked at the air filter about 10 days ago. This time I bought a 2 pack but non oem
3,343
This evacuator-valve was damaged on my JD diesel compactor. I simply ordered a new one on Amazon. It states:
  • The Donaldson Vacuator Valve Is Essential For The Proper Functioning Of The Air Cleaner. In Two-Stage Air Cleaners, This Valve Is A Vital Part Of The Pre-Cleaning Stage. Like The Other Donaldson Products, This Vacuator Valve Is Durably Constructed To Withstand Whatever The Environment Throws At Your Truck.
https://www.amazon.com/gp/product/B015YRHR9U/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
(Your size may differ…this was on mine.)
If you place your hand beneath the evacuator while the engine is running…you can feel a slight expulsion of air with each stroke of the engine. If you slightly squeeze the valve to open it slightly…dust, dirt, bugs, straw and any other foreign object inside will be expelled. This is something which should be done regularly.
If yours is damaged…simple….replace it.
