What did I do?
Jasper2018
Kubota L3130. LA723 FEL, L3901 HST, LA525, bush hog rotary cutter,
May 25, 2021
49
22
Florida
L3130 with LA723 loader.
I ordered a ssqa adapter plate and New bucket from EA.
When the ssqa arrived I installed it as per there video. Knock pins out installed ssqa. When bucket arrived I picked up bucket tried it out and won't dump. I dont know what I did wrong and hoping someone here can help.
I've attached some pics of the setup to help. 20220406_141713.jpg 20220406_141706.jpg 20220406_141705.jpg 20220406_141721.jpg 20220406_141713.jpg 20220406_141706.jpg 20220406_141705.jpg 20220406_141721.jpg 20220406_141246.jpg 20220406_141706.jpg 20220406_141246.jpg
6,988
To my eyes, it looks like maybe you have two things happening:
1) the angle of the bucket in the backside where your SSQA attaches, appears to be a smaller angle than the other bucket in your picture. The bucket in the background has a steeper (almost perpendicular) angle on the backside of the bucket which should allow a steeper dump angle.
I would suggest trying it with that other bucket shown in the background of your picture. Perhaps the new EA bucket is incorrect for your set up?
2) The SSQA mounted on the tractor has the bottom pin (the one that attaches to the loader) pretty far back from the face of the SSQA plate. Someone with an L series tractor could maybe measure theirs (with factory SSQA). It just looks much further away from the bucket than on my machine.
edit: not sure if this helps but look at the relationship of the pins and steepness of the back of the bucket in mine. Granted, this is a B model tractor, but I think the angle of the backside of the buckets across most models/series are pretty similar. The back of you EA bucket doesn't look anything like it.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,862
2,394
WestTn/NoMs
I've attached some pics of the setup to help. View attachment 77862 View attachment 77863 View attachment 77864 View attachment 77865 View attachment 77862 View attachment 77863 View attachment 77864 View attachment 77865 View attachment 77866 View attachment 77863 View attachment 77866
Looks like you need some more parts. I'm not sure what they're called, but I've circled them in the picture below.
The parts list is confusing for your tractor. Some bucket setups show them and some don't. Your arms have the bushings for them. Did you get the adapter from Kubota or aftermarket?
6,988
OP's definitely look aftermarket. Looks like it says "LONG" on the tag.
jimr63
M5-091HDC, L47TLB, L4701F, ZD1211-72, GR2120-54, RTV-X1140
Jun 24, 2015
121
SOMD
You’re correct and I’m pretty sure those linkages should have been necessary for the pin on bucket to work correctly as well so they should have already been there. Maybe not, but those cylinders are extended so far as to make me think so.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,862
2,394
WestTn/NoMs
Thanks. I see that now. I got an ATI adapter for my L35 which has the bucket links. The ears are set back like OPs to allow for the links, so I think the angle is right.
What's confusing is the pin-on buckets in the parts list use the links, but the SSQA ones don't. The fork frame and bale spear shows them.
Kubota made a SSQA adapter that apparently didn't use the links.
Maybe one of the old-timers can straighten us out.
Jasper2018
May 25, 2021
49
22
Florida
I kept the linkage arms as you described. Tomorrow I will remove the ssqa add put on the linkage arms.
Thanks to all who responded.
I will post tomorrow how it goes.
Daferris
LX2610
Nov 23, 2021
496
423
Mid-Michigan
Also after you get the linkage on does the block in the photo attached hit the bottom of the loader arm also???? SSQA.jpg
7,652
Also after you get the linkage on does the block in the photo attached hit the bottom of the loader arm also???? View attachment 77878
In this picture it looks like your locking pin is not in the mounting hole. There is space at the bottom of you quick connect, and the lever is not all the way down.
Be careful to make sure both pins are fully engaged or you will twist the alignment bar.
11,055
You don't need to remove the SSQA adapter.
But as others have said you do need to put all the bucket links back on it!
It also looks like the SSQA is out of time(one pad hits the back of the bucket before the other)
this will make it impossible to latch both latches.
You will need to fix that timing, it's easy to fix, just ask after you get the links on.
Jasper2018
May 25, 2021
49
22
Florida
Update on linkage.
Linkage went back no problems. Also changed pins. Still need to install zerk fittings, and grease everything up.
Thank you all
Derek
