What about a " used kubota tractor " buyers guide.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
Leafy England....
I had a mad idea this afternoon that maybe there should be a guide on OTT for any potential buyer looking to invest in one of the older (better ;) ) tractor, B series L series M series etc .
I am no mechanic but from my experience so far on early "B" series tractors is that the same old areas are prone to neglect etc, also due to the difficulty in accessing some parts , problems go overlooked until it is too late.
To date, from all my rebuild projects etc the same old items need repairing/overhauling etc, and its not allway due to the hours that the machine has run up.
On my B6000, B7100D, 7100HST, and now my B8200D , the brakes were all jammed, the seals shot etc but the shoes were fine.
same with the stearing, ball joint were loose due to lack of lubrication etc. the front axle pivot was really loose and had no lube.
another area that has been the same on all my machines are the metal hose sections and the water pump bearings/seal, all have been leaking and all the tubes were correded to a varying degree, rubber hoses were not much
better.
And, the list goes on, all probably avoidable with a little maintance now and again, but the unsuspecting buyer looking at purchasing a used machine that maywell be 25-30 years old is that they may not be aware of what to look for.
A nice shiny tractor may look nice etc but it can be hiding a whole heap of problems ,which, with some simple checks would save a lot of future expense and disapointment.
What say we compile a buyers guide , not a "buyers Bible" moreso a checklist of key areas on kubota tractorsthat are known to suffer from problems etc, and then they can make a more informed descision on what they are potentialy buying.
Simple things like checking the brakes dont drag or bind by tring both sides independly and just sticking the tractor in netruel and try pushing it along, sticking brakes on one side will soon become clear.
I can think of at least 20 items now of the top of my head from my projects so far that are prone to wear & tear etc by lack of maintance etc and which covers a whole group of kubota tractor all in the early b series in the same way, and 20 is the tip of the iceberg, also it depends what you expect back from your investment as to how far you go through the tractor. At 25-30 years old a lot will be worn, but thats not to say its over the hill, far from it.
A simple check can show up a lot of problems before its too late.
I dont have any problem with buying old tractors, and as such will quite often not check certain parts on a tractor i am looking to buy becuase from experience i fully expect to have to replace or repair them, but the less aware buyer may not have the same option of repair such as i do.
Dealer repairs of even simple parts can be very costly, so a buyers guide could be a great tool for the new kubota buyer out there.
I hope you all can see what i am nattering on about here and i am mor ethan happy to start it off with my suggestions on areas that buyers should check on certain model, but the same check will apply to a whole range of machines due to the shared type of equipment.
how about it Vic and mr K. ;)
cheers all
rob
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
I for one see your idea and get your point but with anything in life buying used is a gamble. Atleast we do have the forum for anyone to stalk in the shadows or become a member and ask all the qustions they can. I'll point them in your direction for expert advise on the B series tractors.
4,311
I agree but maybe like KNOWN problems MDL xyz has a known problem with 4 th grar stripping out,, check it before buying,, you know something like that maybe ORRRRR service recall notices MDL xyz has a recall due to a faulty fluger bearing,,,you know
300zx
1979 B7100D, 2009 ZG20, 1991 B2150, 1990 B6200
Dec 1, 2010
445
Forest, VA
I am in also. I wouldn't buy another used Kubota without checking for water in the steering box. Once frozen, you are assured of a steering box repair. Also, I always check for piston blowby by checking the crankcase vent after the tractor is warm. I assume these are the type of ideas were are trying to accumulate.
John in VA
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Could this wind up potentially being a bad idea. I know I hear all to often that people lurk and stalk in the shadows and gain knowledge about Kubotas from here before they pull the trigger and buy one. My thoughts are if you throw out too much info about what to look for before the purchase of a used tractor someone might go else where to buy a tractor.
Which in a way is a real same that any tractor gets neglected from a previous owner not taking care of their equipment. And everything Rob has stated in his findings has been due to neglect and not properly servicing a tractor from the previous owner.
Maybe its just me but I'd hate to scare off a potential buy because he/she read to many bad things on here about it before they bought it. And all those parts that need fixing came from abuse and neglect.
Rob
Nov 22, 2009
679
Leafy England....
I agree with your concern's Eric, but there will allways be the pros & cons with anything like this.
What i had thought was this, a check list of items to inspect or double check when viewing a potential new purchase etc, not a total "what's worn out hit list " just the items that are most commoly found to occurr , a lot of items could be misdiagnosed , hence just a check list for the items concerned and drief description on what to look for and maybe how to test.
The problem is also made worse by this, that unless you have documented history with the tractor such as sales receipts, service bills etc, and the original bill of sale, there is no way of knowing had many previous owners there have been nor what has been done to the tractor.
Its all good & well going to a seller and asking him whats been done, but unless he's the original owner he wont know, even with the best will in the world and a genuine seller you could still end up with a whole heap of problems.
The phrase " its worked fine with me since i bought it " and " its never let me done" are simply just words and too many buyers take it to heart that they are buying a problem free machine, its rarely the case now i'm afraid.
It's a sad reality in this day and age that the Phrase " BUYER BEWARE" is a very appropiate one, there are good buys & bad buys, if you get a good one its all smiles, if not , well we have all seen the horror stories.,
From my previous good and bad experiences with older machines i personally would find a used buyers guide/checklist a good tool, and it should be used as a tool to assist in making a more informed descision on any purchase.
I dont think it should really affect any body selling etc to be honest, as a lot of buyers may have freinds or collegues that work in the industry and such would be in a better position to advise any potentail buyer on what they are getting.
I was aiming the guide to those who are not in such a position or they have a good working mechanical knowledge, but not specific to the kubota ranges etc.
I agree that sometimes a little knowledge can be more dangerous than non at all, but then we live in a computer orientated world now and the infor is out there anyway, it can only be a benefit if the info is supplied in a more user friendly format and that the data supplied is reliable.
Anway, maybe there should be a vote on the viability etc on making a guide.
I'll leave it with you all guys.
happy new year.
rob
hodge
Nov 19, 2010
2,954
517
Love, VA
I don't know about a vote- it's Mr. K and Vic's forum, so the decision is theirs. It could be a running sticky, where people post on known issues to look for. The information should be based on a model they have and have experience with, not heresay.
There could also be a "praise" sticky- "I have a whatever model Kubota, and this is what I appreciate about it compared to another tractor that I had" type of thing- the attributes balancing out the "works in progress".
I like it, especially in light of the 3ph issues on some of the Kubota models, as an example. If Kubota won't address the jumpy/jerky issues, and I were shopping for a new tractor, knowing which models have the issue would steer me away from them, but keep me buying a Kubota. I see Eric's concern, but I also believe that it can keep people buying orange, too. Every line of tractors has their own issues, and Kubota isn't any different. It is more important to know what to look for, than to run to another color and hope for the best.
4,311
The BIG "K" like every other manufacturer has problems just look at the recalls of the big 3 autos. I think the idea of a check list is a good one, Im sure I passe up some pretty good deals on bubots cause I had no idea what to look for, just like a car truck or bike or homes for that matter. If you have no idea where to start, odds are your gona get screwed. Just MHO you understand and theres no way everything could be listed but enough stuff for a damn good start for a prospective used tractor buyer not to get hammered by winding up with a junker that will cost more to fix than its worth,,again just MHO
Rob
Nov 22, 2009
679
Leafy England....
As a follow-on to my last post , here is a very good example for the pros side of having a guide, and is another good reason why i posted this thread.
Over here in the UK there has been a quite large increase in the sale of grey market compact tractors recently, especially from sellers using ebay to promote sales.
That is all good & well in an ideal world, but we don’t live in an ideal world .
There does appear to be a much bigger market for the grey models over here than elsewhere, maybe due to differing legistration etc.
Sellers put all manner of compact tractors for sale 99% being grey imports, and from the main stream factories, Kubota,yanmar Mitsubishi etc.
That’s all fine by me, it’s a global market place , grey imports are built to just the same quality as other kubota’s model, just a differing end market.
What does concern me is the way that some sellers use downright misleading wording and descriptions in there adverts etc, I wont use specific wording , but they imply certain models are the same , ie B7001 is the same as a B7100 etc.
I would challenge anyone to prove they are, because the simple truth is that they are Not!
As with numerous Kubota models, they share some similar parts but at the same time also have a lot of parts missing and would not allway comply with safety regs etc.
Internal specs of the gearbox/back axle differ also.
Anway, a good friend of mine was in the market for a good use compact, we started chatting about it and I recommended looking at a Kubota.
A few week later he called me to say he had purchased a Kubota B7001 in as new condition via ebay, but not directly on the site, he delt with the seller directly through the sellers business.
He gave me a good description of it and what he paid, ( a lot in hindsight for a pile of rubbish) . A few days later I made a visit to see him and his new pride and joy, when I got there only to find him in the garage with his new machine , and a very angry look on his face.
He said it had been running for an hour slowly getting less and less power , then just stopped, and it woud not start again
To be honest I felt a bit guilty having recommended a Kubota and his first purchase has broken already.
I had a good look at it and was appalled at what I saw, the tractor looked good, all nice shiny paint on new bodywork, tyres were new also but underneath that was a right mess.
Everthing that wasn’t body work had been repsrayed , and , I do mean everything including the oil filter, hoses the lot all painted.
Anyway, the fuel filter was clogged there was no airfilter element the rear axle half shafts were really worn and had small pieces of tin jammed in to take up the play.
The glow plugs did not seem to be much better either.
In fact the list was endless, I sorted the problem for him to get up and running again, but he asked if I could go right over the machine and make a note of the problems.
I did and left him to sort the rest out with the seller, which I think is not doing much to resolve.
He paid nearly £4000 for this pile of shiny metal, man he was really ripped off.
Maybe if he had been able to access a guide he would have been in a better position to ask questions etc and make some checks before parting with the cash.
The problem can only get bigger in my view, the amount of sellers is now is growing, everyone is buying in JDM tractors, repainting them etc and servicing them to very differing standards.
Selling as new or nearly new machines, or even totally factory rebuilt, all very questionable in my view.
Also saying full spares back from Kubota etc, not so, if you ask for parts for a eg,B7001 in the uk you will get nowhere and Kubota UK will not help either.
Its all down to that phrase again “BUYER BEWARE” .
yes there are a lot of good tractors for sale for genuine buyers, but its finding them, and the problems are not confined to JDM models either .
Sorry for the long rant here guys but I suspect my friend is not the only victim of similar sales etc.
Have a good one
rob
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
There's a valid reason why a "what to look for" list doesn't exist already. And that reason being is nobody would ever be able to sell anything if all they hear is bad things about stuff. That applies to both new and used. Figuring the new gets old at some point. Same goes for tractors as it does buying a used vehicle.
If Ford Chevy and Dodge had a list of the crap that went wrong with them years down the road you damn sure wouldn't want to buy one knowing full good and well its going to go to shit years down the road.
It's a gamble and a chance you have to take when buying anything used. Used car, used house, used bicycle, used roller skates its a risk you take. If you don't like to take that kinda risk then buy new and you cant go wrong.
Rob I'm sorry to hear your friend got taken for a ride and was sold a hunk of metal but that problem does exist with anything you buy used. Crooked people taking advantage of other people. Used care salesmen are the worst in the world about that one but yet we still keep buying up used cars from them.
dmanlyr
L3200, Hustler Super Z
May 30, 2012
330
Graham, WA
While I am not opposed to a guide per say, I think the grey market has been pretty much covered, at least for anyone who wants to spend 5 to 15 minutes on the internet. Big thing is, since it has been covered, and people are not even willing to research it for even a few minutes, why would they bother to read a guide either?
As to a actual guide, well it could only cover the newer models and then at relativly low hours, for anything that is 25 or 30 years old, anything and everything can fail, there are no weak spots, those would have shown up long before. Same with lots of hours. Anything and everything can wear out. Those weak points or problem areas most likely have already shown up and been repaired many hours ago.
Pretty much like electronics really, those that fail, generaly fail at start up or within a very short operating time, after that it is a relativly long life span until the whole thing just starts to fail, in any and many ways.
Then, throw in maintenance or lack therof, and a two year old tractor that was beat and had zero maintenance may be in worse shape that a 15 year old tractor that has been used properly and maintained. How could a guide cover this? Other than in one simple statement, "if used and maintained properly" and how would anyone buying any piece of equipment know exactly how it has been maintained and used for 5, 10, 15 or 30 years?
Ya sure you can look at condition, but there are a lot of nice looking, garaged tractors out there that have not been maintained (but washed and kept out of the weather so as to not rust) and are falling apart internally. Again, not to be a naysayer, but at best a guide could be a list of points to look for, but at best it would give a false sense of security as to actual condition.
Buyer beware when it comes to used...and even when buying new at times it seems!
Carl k
L3800DT
Jun 3, 2012
42
Rice, Virginia
Hi Rob, I found this regarding what to look for when buying a used Ford 8N. Is this what you have in mind for your Used Kubotas Buyer's Guide, but written more specifically for Kubotas? If it is, I think it's a great idea. The Used Kubota Buyer's Guide could be organized in three parts 1) problems to watch out for common to all tractors (including Kubotas), 2) problems to watch out for regarding diesel engines, 3) problems to watch out for that may be specific to particular Kubota models or years. Just a thought.
Something to think about from the FAQ section of Smith's Old Ford Tractors www.oldfordtractors.com:
(This is just an example of a used tractor guide. It will need to be rewritten to be applicable our tractors.)
Q: "What should I look for when buying a used 8N?"
A: A lot depends on what you plan to do with the tractor. Obviously, if it is to be a work tractor only, some of the cosmetic and originality issues will not be nearly as important as if you were looking for a restoration project. Everyone looks at them differently. I'll try to cover the basic stuff. The 8N's didn't change a lot from '47 to '52 but there were some important changes. In late '49 the steering box was much improved over the early models. Loose steering was common on the early models and the early steering boxes are more difficult to rebuild satisfactorily. In mid '50 the distributor was moved to the side of the engine and access to the points at tune up time got a lot easier. The later models also had a Proofmeter (tach and hourmeter) which can be handy at times. The early 8N's are fine tractors, but the later models seem to be more desirable among buyers. This isn't usually reflected in price or value, but people do give it some weight in the decision to buy or not to buy a particular tractor.
The first thing to do is to walk all around the tractor and give it a visual inspection. Don't be blinded by fresh paint. It can mask a lot of defects, and a poor paint job is worse than none at all. And, don't confuse "painted" with "restored". There's a BIG difference. Don't immediately reject one for lack of a good paint job, either. It may be in excellent mechanical condition. Look at the sheetmetal. It should be reasonably straight and have no large rust outs. Nice original grilles, hoods and fenders are valuable and can be expensive to replace if needed. Look at the tires. Look for weather cracking, splits, cuts, chunks missing, and amount of wear on the tread. The tires should match, size and brand, and rears should have at least one inch of tread to be considered good. Tires can be expensive, especially rears, which will cost $350-$450 (with new tubes and labor) to replace. Good tires are a plus. Check the rear rims for rust from calcium cloride inside. If the tires are filled and are leaking, the rims may be shot. It's usually most noticeable as being wet around the valve stem.
Starting at the front, open the radiator cap. Is the coolant clean? No oily stuff floating around? Oily stuff can be just some stop leak, or it can mean a bad head gasket or worse. Look through the grille and underneath and from behind at the radiator. Any leaks or damage? A radiator repair will be $50 or more. New replacement radiators from China sell for around $150. Wiggle the fan blade to check the bearings in the water pump. It should be tight. Any leaks? New water pumps cost around $60. Does the fan belt look ok? Check the radiator hoses for cracks or soft spots. Look at the head where it bolts to the block. Any leaks there? Look at the left side of the block where the coolant draincock is. Check all around the area in front of the draincock and above it for cracks in the block or signs that a crack has been repaired. If someone has let the engine freeze up in the winter, this is where it usually cracks. Be wary of cracked blocks, especially if repairs have been poorly done. A cracked block makes the tractor worth substantially less and trying to find a good used block for a reasonable price can be a very frustrating task. On the other hand, a crack that has been properly repaired won't affect the performance of a work tractor one bit.
Pull the oil dipstick out. Look for signs of water in the oil (milky) and see how dirty it looks. While you're in that area, try to read the serial number. This will tell you what year the tractor is (many owners/sellers don't actually know what they have). Look at the fuel sediment bowl. Is it full of rust particles? This could indicate a gas tank with rust problems inside. Look up under the hood at the gas tank. Any leaks or patches? Look at the electrical wiring. Open the fuel door on top of the hood and look at the wiring behind the dash. Does it look frayed or burned or in need or replacement? How do the battery and cables look?
Look at the radius rods that support the front axle. They should be straight, not bowed upward. Shake the left and right tie rods. All 4 ball and socket ends should be tight. Grab the front tire and push/pull inside and out on it. The wheel bearings and spindles should be tight, no play. Look at the manifold. Is it solid? No holes or cracks or carbon marks on the block where the gasket is burned away and leaking? A replacement manifold will cost around $60. How's the muffler? New ones cost about $20. Does the carburetor look as if it is now or has been leaking gas? Is the air cleaner and inlet tube intact and connected to the carburetor?
Turn the steering wheel left and right to check for excessive backlash in the steering. Does one front wheel start to turn before the other starts moving? This indicates a misadjustment or worn sector shafts in the steering box. Look at the surface of the clutch pedal. Is the tread mostly worn away? This is an indication of hours of use on the tractor. Move to the rear tires. Grab the top of the tire and push/pull toward and away from the center of the tractor. Does the wheel have side play? Do you hear a clunk when you push/pull? This can indicate a misadjustment in the shims that load the rear axle bearings. There should be very little, if any, play when properly adjusted. If it feels loose, watch the nut on the outside of the rear hub while you push/pull. Can you see movement behind the nut and washer? This indicates a loose hub on the axle. It may be able to be tightened, but if the movement is excessive the hub is most likely shot from running loose. New hubs are around $60 each. Look inside the wheel at the brake drum area. Any signs of grease leaking from the rear axle or from the brake drum? Leaks here are common, mostly from bad axle seals. If the rear hubs are loose or misadjusted (clunking) the seals will never keep the grease in the axle where it belongs. The brake shoes will be saturated with grease and need will need replaced. Figure $100 for new brake shoes and axle seals (parts only).
Go around to the back and unscrew the PTO cover cap (if it has one). If oil is leaking out around the shaft it will need a new seal installed. Check the splines on the pto shaft for excesive wear or twists. A new PTO shaft can cost $100 or more. Inspect the lower lift arms. The ball sockets are likely worn some and will be loose, but should not be so loose that it appears the ball is ready to pop out of the socket. The arms should not be bent or have been welded or braced. Make sure the front lift arm attaching pins in the lower axle housing are tight and are not leaking oil. Turn the crank on the right hand side leveling box. It should be smooth and the shaft should not wobble. Look at the upper lift arms. There should be no bends or welds there, either. Go to the right side of the rear housing and remove the dipstick in the gear oil/hydraulic reservoir. It should appear clean and not a milky tan. This is a common place for moisture to collect and if you buy the tractor you will want to change the gear oil soon regardless of it's appearance now. It will, however, give you an indication of the previous owners maintenance (or lack of). Be sure to look under the tractor from front to rear. You never know what surprises you might find in the way of previous repairs, etc.
Now that you,ve done the visual inspection and rated what you've found (plus and minus) it's time to start the engine. It should turn over briskly, with no groaning, dragging or grinding noises. The engine should start easily. Check the oil pressure. It should be 25 to 45 psi cold. Any less is a little low and a higher pressure means someone has put a heavier spring in the relief valve in a misguided attempt to raise the low oil pressure readings when the engine is hot (it doesn't work that way but people keep trying it). Listen for knocks or other abnormal noises. Carefully open the radiator cap and check the flow. It should be moving a lot of water through there (unless it has a tight thermostat in which case you need to look in there after it has warmed up). Rev the engine and check for smoke coming out the back. Blue smoke means it's burning oil, indicating worn rings. Black smoke means it is running too rich, which usually indicates a carburetor problem. A white smoke can mean the engine is burning coolant from a blown head gasket or cracked head. Check for blow-by coming from the oil filler/breather cap. If blue smoke is puffing out of there, the rings are badly worn. Let the engine idle down to a low rpm. Listen carefully. Abnormal noises or misses or pops from bad valves should tend to be more noticeable at a slow idle. It should run and idle smoothly if it's in good shape. Watch the oil pressure as the engine warms up. It should not drop below 20 to 25 psi hot if everything is in good shape. Less than 20 psi at slow idle when hot indicates that wear in the main/rod bearings and/or oil pump is becoming excessive. That is not to say the tractor won't continue to run ok with a lower oil pressure but it is an indication that something is worn. Check the ammeter. While running, you should see between one and 10 amps on the "+" side, indicating that the generator is charging.
Depress the clutch then let it back out (shifter still in neutral). Listen for noises from the throwout bearing and bearing noises in the transmission. Depress the clutch pedal and engage the PTO. Let the clutch back out. Engaging the PTO should not create any new noises from the hydraulic pump or PTO shaft bearings. Check that the PTO is in fact turning. Raise the quadrant control lever to raise the rear lift arms. They should move quickly and smoothly all the way to the top (top position will have the eyes in the outer ends of the lower lift arms around 3 feet from the ground). It's best to have a load on the lift arms for testing such as a heavy rear blade or a mower. If nothing is available, you or someone else should stand on the rear lift arms (hold on to the fenders). Raise and lower the lift a few times. It should be smooth and not have an excessive amount of "knocking" coming from the pump area. A knocking sound indicates wear in the eccentric bushings that drive the pistons in the pump. Most will have some noise, but it should not be excessive. If the lift is jerky coming up, there could be a bad or stuck valve in the pump. Raise the lift to the top position (with load) and disengage the PTO. The lift should hold the load in the up position for 20 minutes or longer without drifting down. Less than 20 minutes can indicate worn rings or a scored lift cylinder. A really tight system will hold the load up overnight with little drift.
Time to go for a ride. Depress the clutch and shift into second gear. There should be no grinding as the shifter moves. If there is, and if the free play in the clutch pedal is adjusted correctly (3/4"), then the clutch disk is probably sticking to the flywheel. This can indicate that the front seal in the transmision pilot shaft is leaking gear lube onto the clutch disk. Slowly let the clutch pedal out. The clutch should engage smoothly with no grabbing. A grabbing or a shuddering motion also indicates gear lube has leaked onto the clutch disk. Pull the throttle to increase engine speed. The engine should respond quickly and pull smoothly up the maximum rpm then the governor should level it out. Look back for signs of smoke behind you. Try the brakes. Pressure on the brake pedals should make the brakes try to slow the tractor. Stop and try all the other gears one at a time. Taking off at a fast idle in 4th gear should tell you if the clutch is slipping. Pull the throttle wide open in 4th gear. Again, it should accelerate smoothly and then level out. Check for smoke again. Notice how the tractor steers. It should not be wobbling, or wandering and should respond to small changes in the steering wheel position. Push in the clutch and hit the brakes. You should be able to lock the rear wheels if the brakes are good. If standing on the brake pedals barely slows the tractor, you likely have gear lube on the brake shoes from leaking seals and will need new axle seals and brake shoes.
By now you should have a pretty good idea of the condition of the tractor overall. It won't be perfect. It's 50+ years old and probably has worked hard all its life. Add the positives and the negatives and consider the asking price. If there are too many negatives, keep looking. Anything can be fixed with enough time and money, but you may be ahead in the long run to pay more for a tractor that's in good shape to start with than to buy a rough one and spend a fortune on it to repair everything that's worn out. I certainly haven't covered everything, but these are the basics. If you are not familiar with tractors, old cars or mechanical equipment in general, consider taking a friend who is or even paying a mechanic to go along with you and look the tractor over before you buy. It could save you a lot of money and headaches. Good luck!
gpreuss
Oct 9, 2011
1,166
Spokane, WA
Karl K, Thanks for the post! Great guide!
When I sold my L185, it was understood that Kubota no longer had major parts. I'd gotten scared when the radiator neck blew off, and Kubota said they didn't have one. I'm near retirement, and bought a new L3200, because once retired I wouldn't be able to so readily. Since I've joined OTT I think maybe I was wrong, but it is still something big to consider. I can find more parts for that older 8N Ford than I can for my Kubota. I can buy a complete running 8N for parts, for next to nothing. Not so, with an older Kubota. The deal is, there were LOTS of older Fords, MFs, JDs etc. sold, not too many Kubotas at the beginning.
So we need to keep that in mind with the older tractor - you are buying something that either already is or soon will be not supported. It does not make the tractor less, just maybe riskier.
