Warning light in cluster?
willpullem
M135x
Mar 9, 2017
Rockbridge, KY
My first post here. I have a 2009 m135x when I first crank the tractor the "!" that is right of the temp gauge stays illuminated. When the tractor is turned off once it's warmed up and restarted the light does not come on. I replaced both the air intake sensor and the water temp sensor but that has not fixed it.
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
Check your owner's manual, if you have it, but a guess might be something to do with the oil level'or pressure. When did you last change the oil and filter? Is oil suitable for temperature?
willpullem
M135x
Mar 9, 2017
Rockbridge, KY
I was reading on another post about the ecu ground(s). Is the ecu behind the right interior panel?
Amaranthian450
Many Kubota tractors, haying equipment, seeding equipment
Jul 9, 2026
Manitoba
Hey did you ever figure this problem out? Mine 135 is doing this now and is also now in limp mode. Banging my head off the wall on this!!
