Wanted Turf Tire/Wheels for L2350DT Kubota
horndale
Central Texas
I am looking for a set of turf tires and wheels for my L2350DT.
I believe it calls for 13.6X16 for the rear, and 24x8.50x14 on the front. I'm sure there are othe combos that would work if the ratio is roughly the same.
Needless to say, these are way more than I want to spend from the dealer.
I have AG Tires/ wheels I could trade. I also have a 4' Bush Hog brand cutter that I would consider trading as well. Buying them outright a possibility depending on the price.
Horndale
I am in the Central Texas area.
meanjean
Kubota MX4700
Aug 10, 2010
922
Hazelridge, Manitoba
I looked into turf tires for my tractor, L1801.
Was almost $700 after taxes.
I would encourage you to look at semi truck tires.
They stand roughly 40 inches tall.
Weld a plate onto the rim and drill the pattern you need for your machine.
Will cost considerably less and they should be able to handle the weight as required.
What do you think?
meanjean
Kubota MX4700
Aug 10, 2010
922
I did in fact go that route, kinda.
My tires came off a milk truck.
Roughly 8 inches wide.
You could pick up a set of truck tires and rims for under $100 bucks.
A few buck$ for the plates, few more for the welding.
Way cheaper than turf tires.
I can send you pics if you like.
Zip me an email here:
Jay.desrosiers@winnipegradio.rogers.com
mhreb71
L3600 4WD
Feb 2, 2011
Scott,La, USA
I have a set I took off of a L3600. They are 27x10.50x15 on the front on a 6 hole rim with about 50% rubber left. They are 41x18.1x16.1 on the rear on a 6 hole rim with about 80% rubber. They are all 6-ply Carlisle tires. I'm in South Louisiana. I'm asking $400 plus shipping if needed. I'm not sure if these would work for you, but maybe others. Thanks.
horndale
Central Texas
I've done a little researching and think that the size/ratio will work.
Although mine are 6 lug front and back, I think the next step is to find out if they will bolt up and physically fit.
Do you have 2 lugs and 4 lug bolts on each wheel?
Are these Galaxy brand tires?
I wish Kubota would have some sort of fitment chart available for these sorts of things. It sure would make things easier.
markvandillen
L200
May 25, 2011
Truxton, MO
Horndale
I have a 1970 L200 that has 9.5 x 24 rear turf tires that I want the
AG tires for--wonder if yours would fit mine?
jeffcity2
B7800
Jun 13, 2011
Loose Creek, Missouri
Hi a new guy here and I am have the reverse problem. I just bought a B7800 with Truf Tires and want to put a set of R4 on it. My problem is that my tires are like new and the dealer wants over a $1000 for a new set. If you have not done anything yet let me know maybe we can work something out.
Thanks!
200mph
Mar 3, 2017
1,228
65
PA
Did you ever get your turf tires? I have a set for sale.
I wish you luck with this, but you are replying to a 9 year old post. :D
