Upgrade options for L2501 aux hydraulics?
Helix
Kubota L2501
Mar 13, 2025
I am looking to run a drive motor on the FEL of my 2020 L2501 using a 3rd function valve kit from my power beyond port. The motor is specd for 7-18 GPM up to 3000 PSI. The hydraulic flow rate of my tractor as I understand it is 5.15 GPM. Is there any way to upgrade the pump to get a little extra flow here? If I use shims to bump up the pressure, would that also bump the flow a little? The other option would be a PTO pack but trying to avoid that if possible. Thanks in advance for the help!
biketopia
Feb 15, 2024
330
328
Warrenton VA
What is this motor going to be powering? There isn't going to be an economical way to get that much more flow, more flow is more displacement. Plus that motor wanting 7-18GPM, it will perform marginally at its task with 7gpm anyway. An additional 1000psi of hydraulic pressure, you also risk damage to the rest of the tractor's system.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,566
2,025
Western MT
I think you have to go with a PTO pump or spend a lot of money making some other pump fit and then work correctly with your hydraulics the rest of the time.
Helix
Kubota L2501
Mar 13, 2025
It would be a drive motor for screwpiles. So a low rpm high torque auger type motor. I'm OK with the standard 2250psi that the machine is equipped at. It will generate the torque I need. Just looking to get a feel for what it would take to bump up the flow rate, if it can be. Thanks again. Here is the gpm to rpm of the motor chart. I have no issue with 6 RPM, this will be suitable for my use.
biketopia
Feb 15, 2024
330
328
Warrenton VA
Unless you're driving those screw anchors into relatively rock-free, sandy soil, the substantial torque increase even going up 1-2GPM would be significant when dealing with clay and heavily compacted soils.
8,756
There is no simple pump upgrade.
Upping pressure lowers flow it doesn't raise it.
5.1GPM on a motor thats min is 7 GPM, you'll get about 100psi and 1 rpm out of it.
That is if it will turn at all.
Simply put, you will need a power pack to run it.
You're looking at about $2500 for the power pack.
Or get a skid steer or track loader!
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
785
679
E.
let me throw another type of spanner into your gear set over and above flow rate......
The L2501 has pretty spindly loader arms. Are you not worried about the forces of installing screw piles on the potential damage?
Helix
Kubota L2501
Mar 13, 2025
I'm not too concerned with this small of a drive. They are designed for light mini excavators and walk behind skid steers. I've had the L2501 for 5 years now and if anything it has always seemed overbuilt for the power it has. Thanks for mentioning though.
Helix
Kubota L2501
Mar 13, 2025
Thanks again to everyone that responded. After looking further the minimum flow is 2 GPM on this unit. I'll give it a try with the power beyond and 3rd function valve. Not looking to use this all day long.
biketopia
Feb 15, 2024
330
328
Warrenton VA
Interested to see what the results are and how much time it takes to fully drive an anchor into the ground. Post pictures/video!
5,269
Your tractor has a fixed displacement gear punp. Changing relief pressure has no effect on flow rate. Increasing pressure will increase motor torque.
Dam
biketopia
Feb 15, 2024
330
328
Warrenton VA
Dam
I was referencing the screenshot OP posted showing motor input/output. My comment was meant to suggest that going up to a reasonable GPM from a power pack, larger machine, etc. would substantially help him drive the anchors in the ground.
5,269
Actually I did not mean to quote your post.
