Universal snow plow?
cric8192
B1500
Aug 10, 2021
Hello,
I have a grey market B1500 from Japan without a loader. I primarily use this tractor to cut grass but would like to use it for snow removal as well.
Is there a decent snow plow that can hook to this tractor? I am fairly handy with fabrication if need be. The tractor has 1 set of remotes that could be used for lift/lower.
Thanks
4,878
I'd look for a 6' plow off of a Jeep or if that's too long find something 5' and start fabing. Don't think you'll find anything factory. Just use your imagination!
Years back I fabricated a plow on a Ferguson 20. All made up in my mind with a 3" channel going under to be the main support pushing on the rear frame. Used the same method to life as the mower deck used. (I put a belly mower on it) When I went to sell it I was going to keep the plow but the guy was so intrigued by the setup he kept raising his offer. Finally I gave in! Got enough money to pay for 1/2 of a new B8200 !
You can do it. Just sketch it out and start scrounging material, by winter you'll have a prize!
4,475
curious was I , according to TD , it's an 18hp 'garden tractor'., so NO way a 5' let alone 6' JEEP plow will work !
Consider a 42-46" 'lawn tractor' snow plow setup,something for say Cub Cadet, MTD, etc. usually get them for 2-400$. Maybe even buy a 'complete rig' (busted engine ?) and go from there.
