How would I tie into the tractor main hydraulics for my loader and get rid of the rear pto mounted pump. I have a L345DT 1979-1980.
You use an outlet block that replaces the cover on the side of the 3pt lift.How would I tie into the tractor main hydraulics for my loader and get rid of the rear pto mounted pump. I have a L345DT 1979-1980.
I make the blocks ($40) but I am pretty tied up right now. Its a three hose hookup.Thanks for the input, would you have a picture or part number for the outlet block, would I need to tie into the supply and return hard lines that come back from the pump.
Plumbing is hose from outlet block to loader valve and back to block - two hoses. Third hose goes from valve to existing port on transmission. Your current loader valve may not have the third port and if not should be replaced.Awesome, I really appreciate the help, where do I tie the sump in at, can I do it on the large hard line that runs from the pump? Also, Hokie do you know when you would have time to get one made for me?
Or here - thread is 3/8 BSPPOn that model there is no port to tie the sump into.
One of the easiest options is to put a 90° fitting on this drain and connect the sump pipe there.
Your right, if equipped, that is the best, some do not have that port or it's not drilled and tapped.
I'm confused???Ok, so a hose from the 1/4 outlet to the in port of the loader valve and a 3/8 line from the out port of the loader valve to the 3/8 return port, so no blocks are needed then. Where would I run the hose coming from the side tank that was used for the FEL and PTO pump. I am assuming I would still need that extra volume. I so appreciate the patience everyone has in here, not knowing much on the hydraulics but love to work on them.
You have to disconnect your vakve frim the PTO pump and reconnect it to the outlet block. Thats the two existing hoses.Ok, so a hose from the 1/4 outlet to the in port of the loader valve and a 3/8 line from the out port of the loader valve to the 3/8 return port, so no blocks are needed then. Where would I run the hose coming from the side tank that was used for the FEL and PTO pump. I am assuming I would still need that extra volume. I so appreciate the patience everyone has in here, not knowing much on the hydraulics but love to work on them.
