twisted bucket arms..
gravelman
Kubota 2650
Nov 21, 2016
17
WESTMORELAND
I believe i have a slight twist on my bucket arms...bucket does not sit flat unless pressure put on it. Any suggestions as to realigning...
Fladogman
116
82
Crawfordville Fl
If the rear tires are not out of balance pressure wise then one of your cross members are slightly twisted. You can check this with a straight edge. To realign it you have to cut the old cross member out and replace it. I did my dad's tractor last year.
4,432
Begin by having the tractor on a flat concrete surface and measure the center of the rear axle to the concrete. Maybe the tires don't measure the same.
hodge
Nov 19, 2010
2,861
373
Love, VA
What surface is your tractor on? To properly judge, you need to ensure that it's on a perfectly flat surface.
GrizBota
Apr 26, 2023
1,143
728
Oregon
Slight, as in 1/2” over 5 ft width of the bucket, or 3”? If it’s a half inch, just use it. Whatever you’re digging on isn’t going to be that even anyhow. Basically, what problem is this “slight” twist causing, if any?
gravelman
Kubota 2650
Nov 21, 2016
17
WESTMORELAND
all good stuff and i thank you..it is very slight and will just leave it alone. I will check the measurements and tire pressures tho. THANK YOU ALL. No more than 1`/2"
