Trans/hydraulic fluid for B1700
tbronson
B1700 HSD w/ LA302 FEL, B48CA rototiller
Jul 1, 2016
61
Ontario
Is Shell Rotella HD Tractor Hydraulic and Transmission fluid suitable for a B1700?
Thanks!
5,158
Is it geared or hydro?
Geared fine to use just about anything.
Hydro read the label and see if it says UDT compatible, if it doesn't spell that out avoid using it.
tbronson
Jul 1, 2016
61
Ontario
It's HST.
Rotella says it's a universal fluid for trans and hydraulics. The spec sheet says Kubota UDT-compatible. But the B1700 book says Kubota Super UDT. Did some reading on that, and couldn't tell how critical Kubota UDT vs Super UDT is. Cold weather? Longer lasting? Better lubrication?
I just want to get to a basic, it's fine or don't do it, as it's on hand and I need to change out fluid with moisture asap.
5,158
You won't find Super UDT, it obsolete.
There is UDT, and Super UDT2.
Super UDT2 is synthetic and very pricey, and if you have a water issue, stay with UDT.
They are about the same in cold climate
I've a big fan of Mystik JT-5 it's cheaper, but performs excellently in cold climate, I'm not sure if you can get it in Canada?
