So …I get a call. It’s my tenant. “Yards really wet, should do something about this.” (we’ve had ungodly amounts of rain in my neck of the wood.) I like to take care of the people that take care of me, so I run out there to assess. Yep, the yards is pond wet, and we need to install some yard drains.
BUT… A Shovel don’t fit my hand, and I have a Tractor! -I’m so clever.
Or so I thought.
Anyway, I bring the tractor out and dig a quick ditch. This was supposed be a 1-2 day deal.
The ground is all mucky, soupy S#!T. To make matters worse, I had concerns about my down spout drains. There is standing water in them. I go to the city and get the plans for my development. Dial before I dig and proceed to find and dig out the outflow to the street. The idea was to ensure there was no blockage, and add a clean out. So I dig. I proceed to dig up the front yard, only to learn that I couldn’t find the pipe. Digging and mining way, I still can’t find the pipe. (insert neighbors with eyes rolling here.)
After a metric S-ton of work (and a shovel now conveniently fitting my hand) I learn the outflow is Under a concrete porch and dug with something that digs a lot deeper than a BX25.
I now need to rethink my drainage strategy to find enough fall. In order to do that, I need to refill my original ditch so I can get my tractor to that part of the house for the tie in. – I do it. To make matters more complex, I need to avoid both neighbors yards, utilities, and work around the constraints of a tiny yard.
Well since it is so wet, my first ditch was completely full of water and clay doesn’t drain, but I had to back fill it regardless, and did. I then get the tractor back in farther, dug up my outflow point and proceed to work my way back the alley. However, due to the original ditch being in its place I need to move my tractor tight to the house to avoid falling into it and redig the ditch out again. With the angle being what it is, this forces me to over mine, and so reasons I cant explain, I thought it necessary to dig it way deeper than it need to be. After all, you can always throw more dirt back in a hole with a shovel. That is much easier that to have to dig it by hand if you go to shallow.
Except, I cannot shovel this stuff at all. Good God, it’s all heavy wet crap. Making matters work, I have to carry 5 gal buckets of rock to dump into the ditch Because I don’t want to completely destroy my neighbors yard with my tractor, or have it fall into the ditch with the pipe in it. And that ditch attracts Kubota orange like nothing I have seen before!
Like a even more of a complete fool than already stated, I only got 1 yard of drain rock which is far from the necessary amount so I had to finish for the day. I left my yard a complete mess, as well as my neighbors. I mean just walking on it turn it to soup.
I think tomorrow aside from getting more rock, I will get 5 or so sheet of plywood. My plan is to drive on the plywood straddling the ditch and work my way up the ditch sweeping it with the backhoe to fill it in. I will then then bring in sand to go over the top of that.
But obviously, I am not doing well, so I am open for suggestion. ***61514;
Or so I thought.
