Tractor Down! Fuel issue?
FTG-05
L4330 w/FEL, RTV-XG850 and ZD326S
Jul 21, 2013
325
169
TN
I was just getting done with about 3 hours of bushhogging yesterday when my Kubota L4330 died. I had it at 540 rpm at the gearbox, then it started to reduce speed over several seconds, then slowly died. I tried to restart several times, and it sort of started then died again. Each time, it fired less and less. The engine turns over with speed and it sometimes fires intermittently.
Gas tank is just over half full. I replaced the fuel filter (original didn't look bad or clogged in any way) and cleaned the bowl thoroughly, it wasn't that dirty either. When I replaced the filter assembly and turned the fuel cock back on, the filter bowl filled within one minute or so. Following the WSM, I opened the air cock and tried starting again, no joy. Air cock open or closed - no joy.
This morning, I'm going to remove the tank fuel cap and see if that makes a difference. If no joy, I'm going to remove the fuel line at the filter assembly and see if fuel is flowing freely.
What else do I need to look for? The fuel system diagrams on Messick's show no fuel pump on this model. What am I missing?
Thanks for the help!!!
2,430
You need to be sure that you have good fuel flow from the tank all the way to the injection pump. I would do that by removing the fuel line at the injection pump and seeing how much fuel flow you have. Drain into a small bucket to avoid making a mess.
7,066
If you remove the fuel line at the filter and discover no or little fuel flowing, might us air to blow into the fuel tank (with lid off) to displace anything at the bottom of the tank. Could be leaves or rag parts in there.
FTG-05
Jul 21, 2013
325
169
TN
Injection pump = $2114!!!!!!!!!!!
Thanks, I'll do the trace.
Thanks,
2,430
I assume you are going to find a flow issue. Did it run out of fuel or get pretty low?
You may also want to see if turning the key to run or start position change fuel flow while you are checking it. I have no fuel pump on my tractor since the fuel tank is above the injection pump. I know you said you can’t find a pump in the illustration but is the tank higher than the injection pump?
Hugo Habicht
G1900
Jun 24, 2024
929
1,310
Ireland
Hi, the fuel pump is only shown in the fuel parts diagrams. With part number it is included in the injection pump diagram (number 090). Looks like a mechanical fuel pump.
Filter bowl filling in a minute sounds slow to me. You may have dirt or Diesel pest in your tank. Blowing back the pipes with pressurised air will only be a short term remedy, the dirt is still in the tank and will block it again. Disconnect the tank hose from.the filter, there should be a good flow of fuel coming. If this is the case go forward in the fuel system until you are at the injection pump.
And don't worry, from what you are describing I do not think you will have to get a loan on the house for a new injection pump :giggle:
FTG-05
Jul 21, 2013
325
169
TN
the fuel pump (lift pump) and injection pump are shown under the "Engine" assembly drawings vs. the "Fuel System" drawings. The lift pump is shown in the fuel drawings but is not called out.
So here is the plan:
- Tank to filter flow - remove fuel line and check for obstructions. Likely very low since the fuel filter assy filled so fast. Note: I wrote this before seeing or reading post above #6.
- Fuel filter to lift pump - check for obstructions.
- Lift pump to injection pump - check line for obstructions or failed lift pump (~$30).
If the lift pump is flowing well - then it's *probably* the injection pump. :eek::eek::eek::eek::eek::eek::eek::eek::eek:
FTG-05
Jul 21, 2013
325
169
TN
Good news/Bad news:
- Line from tank to filter assembly is clear; flow was full as soon as I disconnected it
- Line from fiter assy to lift pump also clear
- No apparent output from the lift pump; little and sporadic spurts of fuel with lots of air bubbles
Lift pump isn't $30 from Kubota: It's $216. :(
$24 on Amazon.
Is there any way to bench test the lift pump off the engine? The WSM has no instructions for the fuel feed pump (as they call it).
Hugo Habicht
G1900
Jun 24, 2024
929
1,310
Ireland
I think the pump is mechanical from a cam. It only does something when the engine is running. Did you crank it in your test?
9,468
Bench testing that pump is possible.
Just remove the pump and bottle feed the inlet and while holding the body of the pump push the plunger against a board.
You can also verify everything else is fine by bottle feeding the injection pump directly.
Hugo Habicht
G1900
Jun 24, 2024
929
1,310
Ireland
That it spurts every now and then is due to the cam and whatever drives it.
But bubbles means air getting in somewhere. Is your fuel intake hose connected properly?
What you can try to confirm the fuel pump as the problem without spending too much money initially is getting one of those cheap chinese electrical fuel pumps and connecting it to the hoses. Connect the cables to a socket on the tractor or the battery with a fuse near the battery.
FTG-05
Jul 21, 2013
325
169
TN
No joy. :(
Thus far:
- ETA: Changed out the fuel filter and cleaned the filter assy bowl.
- Checked incoming fuel twice - full flow.
- Checked fuel lines from lift pump through to filter housing - clear.
- Replaced air line from filter housing to fuel tank - it was rotten at the filter housing end.
- Blew the fuel line to tank - twice.
- Replaced lift pump with aftermarket pump.
Recharged the battery and the engine cranks just fine - no firing at all. It usually starts within one revolution or so.
What else should I do - before hauling it to the dealer?
2,430
Did you bleed the fuel system of air all the way to the injectors per the manufacture’s instructions? You don’t mention that so I assume that is why it won’t fire up.
4,385
Now sure how old your machine is, but the fuel lines do get soft sometimes, and will collapse and restrict flow, just a thought
FTG-05
Jul 21, 2013
325
169
TN
The WSM only mentions the air vent cock for bleeding the fuel system (page G-35). It states:
"1. Fill the fuel tank with fuel, and open the fuel cock (1).
2. Open the air vent cock (2) on the fuel injection pump.
3. Start the engine and run for about 30 seconds, and then stop the
engine.
4. Close the air vent cock."
Nothing is said about going up to the injectors. Note that the use of the word "injector" in the WSM refers to the tire Schrader valve, not the fuel injectors for the engine. Both Messicks parts diagram for the L4330 and the WSM use the term "nozzle" for the engine fuel injectors. There is nothing in the WSM to indicate that doing anything with the injectors/nozzles is for bleeding the fuel system.
Note that I've tried starting the engine both with the air vent cock open and closed - no difference.
FTG-05
Jul 21, 2013
325
169
TN
Just as with the air line, I planned to replace all the fuel hoses with Fuel Injection Hoses as soon as I could it back to my shop.
4,219
If you are confident that you have properly done all of the above, I would start looking at an "electrical issue”.
Is something keeping the key in the off position? ( maybe internally something is bad?)
FTG-05
Jul 21, 2013
325
169
TN
Fuel filter assembly crack; they replaced it, all is good. I have the old unit, haven't found the crack, but it's covered in crud and it's too cold to be out right now.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,528
3,727
PEI Canada
Glad you got it figured out.
