Tractor does not have ground clearance for the post hole digger
haanzel
L2600DT, G4200 mower
Jul 30, 2014
125
I recently picked up a Danuser G2040 PHD for my L2500, which is rated for 20-40 HP tractors. It has a standard 40" auger attached. The issue I am running into is I do not have enough ground clearance to lift the auger on the back of the tractor. There are no adjustments on the PHD. I am pretty sure the 3 points are on correctly. The bar is on the top toplink setting. On the 2 bottom link bars, the right side does have 2 additional holes closer to the PTO but the left side does not. Any tricks or ideas on how to get this unit to fit?
jyoutz
Jan 14, 2019
3,412
2,478
Edgewood, New Mexico
Most top links have 3 holes on the tractor side and each hole has a different lift angle. Also on my 3ph lift arms there are additional holes . The pin in the bottom hole will increase lift of the hitch.
8,997
Put the bar in the bottom of the three holes and it will lift higher.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,596
2,062
Western MT
Is the top link fully extended? As noted by jyoutz, there should be three holes where the top link goes.
Good luck.
Flintknapper
L2350DT
May 3, 2022
1,965
2,488
Deep East Texas
Pics would help. Surely there is a solution....but might entail modifying the attachment point on the auger arm.
haanzel
Jul 30, 2014
125
Moving to the lowest link did it. Directions said to use the top one so that was what I did.. Thanks again.
5,756
re: Directions said to use the top one so that was what I did..
really, a guy reading AND following directions ???? :giggle:
8,997
Good luck.
Three point PHD's don't use a top link. ;)
Flintknapper
L2350DT
May 3, 2022
1,965
2,488
Deep East Texas
For posterity sake.
The height adjustment is built into the main arm in some form. Glad you got it sorted out.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
794
693
E.
FWIW.... since you have moved to the lower hole to get more lift your augered holes may not turn out to be vertical.
Trick is to creep the tractor a bit for the last 1/2 of the depth. Will give you a vertical hole but slightly elongated at the surface.
cheers
edit: also note that the State of California has deemed the Danuser G2040 PHD may cause birth defects! :unsure: be careful out there what you do around your new purchase (haha)
Warning
This product can expose you to chemicals known to the State of California to cause cancer and birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov/product.
Flintknapper
L2350DT
May 3, 2022
1,965
2,488
Deep East Texas
Flint - This is what I have https://www.danuser.com/attachments/auger-systems/pto/model-g2040
It does not have adjustment holes on the boom like the photo you posted, just a single hole.
Easily remedied. Weld another pivot point just behind the factory one if what you are doing now becomes unsatisfactory. Enjoy your auger and be careful with it.
Don't let anyone get near the auger itself. Been some horrible accidents over the years involving PHD's.
nbryan
Jan 3, 2019
1,313
831
Hadashville, Manitoba, Canada
You may not have this on your 3-point lower links, but mine have a second hole in each that are a few inches closer to the tractor that I can pin the the lifting links to, which increases the operating up/down range quite a bit at the ends of the lift arms. Made the PD15 able to clear the ground. I also use this setting with my chipper so it can lower down beter in uneven terrain.
