tires ?
OldeEnglish
Jul 13, 2014
768
Western, MA
5,264
Not if it's a 4wd, ratio is wrong and you'll just break 4wd components.
If it's 2wd the might work, check the bolt pattern because they change between old and new and different models.
RC = Rolling Circumference
Ag
6-12 RC 69
8-16 RC 93
=.74 ratio
Turf
6-14 RC 72
9.5-24 RC 119
=.60 ratio
Ag
6-14 RC 75
9.5-24 RC 123
=.60 ratio
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
302
northern lower Michigan
Ag
6-12 RC 69
8-16 RC 93
=.74 ratio
Turf
6-14 RC 72
9.5-24 RC 119
=.60 ratio
Ag
6-14 RC 75
9.5-24 RC 123
=.60 ratio
Way to go Wolfman glad to see you're using the numbers and formula to show them how it's done.
Al
tiredguy
Jan 21, 2010
302
been looking for the rims and I just cant find anything any help please be great
Are the rims bad or do you just need new tires? Searching for a used set without knowing before you start is a waste of time really because the wrong thing will break your tractor ( most Kubota's don't share the same bolt pattern anyway so the rims won't fit or the offset is wrong etc ) and you'll be spending big bucks to fix AND have to end up buying the correct tires new when all is said and done.
Al
