Tires For L3250
p.rizzi
Kuboata L3250, Case 1835B, Chevy K3500 4WD Dump, Eager Beaver 5 Ton Equipment Tr
Jan 29, 2015
Hudson MA
I'm looking for turf tires for my L3250 4WD. The rears are 13.6 - 26. Tire store says hard to find those. Can that width be bumped up to 14? Best places to buy tires for our machines?
Thanks,
5,133
Are you trying to find a turf tire to fit an R1 rim?
If so it isn't going to happen, they don't cross like that.
The size you gave is 13.6 - 26 that is an R1 (AG) size not an R3 (Turf)size
If you want turfs you will have to change both front and rears to:
Front: 29x12.50-15
Rear : 21.5-16.1
If you want to replace a set of R1 13.6 x 26 then call these guys.
http://www.millertire.com/categories/tractor-tires/rear-tractor-tires/13-6-26_-12-26/
p.rizzi
Jan 29, 2015
Hudson MA
Wolfman,
The tires I have on my 3250 are in fact turf tires and those are the sizes imprinted on the tires. Dealer tells me they are metric sizes and they are obsolete. I think I would like R3 or R4 tires but not sure what size will fit on the existing rims.
5,133
Take a picture of your current tires, I would love to see them.
Who is the manufacture of the tires?
As far as I know and can research they never made that size in a Turf pattern, but odder things have happened.
What size is on the front?
Your tractor should have:
AG's R1's
Front 6.00-16
Rear 13.6-26
Turf R3's
Front 29x12.50-15
Rear 21.5-16.1
p.rizzi
Jan 29, 2015
Hudson MA
I wll take pictures when I get it back at the end of the week.
Front 8-16
Rear 13.6-26
p.rizzi
Jan 29, 2015
Hudson MA
OK, I was wrong. Tires are 212/80 D15 Front and 355/80 D20 Rear.
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
302
northern lower Michigan
As far as I know Bridgestone ( Firestone Ag Tires ) is the only company that
builds a 355/80D20, and that Pillow Dia is a tube type tire. You can save a
bundle of money by buying the Carlisle 41x1400-20 Multi Trac C/S which is the
same or within tolerance rolling circumference. The bonus going to the Carlisle
is that the tire is tubeless and 6 ply rather than 4 ply too and.If you shop around you'll find that the Carlisle will be less than half price ;-) Over $300.00 ea less!!
The 212/80D15 might be discontinued from the Bridgestone line and don't recall off the top of my head what to do to replace the size conversion wise that's the same rolling circumference.There's some inventory still available though so shop for that too or send me an email and I can help you locate them.
cwtireal@gmail.com
Al
