Tire replacement question
Edringtonfarms
M108shdc, rtv1100, zd21
Feb 25, 2017
Scottsburg,in
I bought a used m108s and it has some small 19.5x24 r4 tires on 24xw16l rims. I am looking to increase to the largest size, which I think is a 18.4x34. Can I mount these on my existing rims? I am doing this for clearance and traction improvement.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
Assuming it's 4wd, are you planning on changing all 4 tires?
A little confused because you listed both front an rear tire sizes.
Edringtonfarms
Feb 25, 2017
Scottsburg,in
I will be replacing both sets. I currently have:
Front :14-17.5 R4 on Amr8993 bw12
Rear: 19.5L-24 R4 on amr8533 24xw16l
I want to go to:
Front: 13.6-24. Rear: 18.4-34 (4WD)
And want to know if the rims will work with new tires. I added a picture of what it looks like now.
MikeyA
2016 B2650 FEL and 60"mmm,1998 B2400 MMM FEL(sold!) BB 4ft BRUSH HOG
Mar 6, 2010
150
West Central Illinois
You will have to change rims also. On the front your wanting to go from a 17.5" diameter rim to a 24", and on the rear, you are changing from a 24" rim to a 34".
5,178
I want to go to:
No, as stated, you have 17.5" rims on the front and you have 24" on the rear, and you want to go 24" on front and 34" on rear.
So buy them as a set in a rim and tire combination. ;)
